Banjo Posted September 10, 2017 Report Share Posted September 10, 2017 (edited) Hi Guys & Gals, These tubes have been reported on here as being very very expensive, if you buy them from Toyota, if they still have them available. Came across these aftermarket ones on ebay out of Thailand. http://www.ebay.com.au/itm/ALUMINUM-SPARK-PLUG-TUBE-FITFOR-3K-ENGINE-TOYOTA-COROLLA-KE20-KE25-KE26-KE30-/152578244696?hash=item23865f4058:g:4PMAAOSwYHxWLPlu I checked with the seller overnight to see whether the price quoted is for 1 off or a set of four (4) as depicted. The seller has come back and advised the price is for 4 off, complete with the oil seal rubber ring. Has any one purchased & used these aftermarket ones previously ? Interested in the quality. Any feedback welcomed. Cheers Banjo Edited September 10, 2017 by Banjo Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted September 10, 2017 Report Share Posted September 10, 2017 Quote Interested in the quality. Can't be worse that factory.. They were also on the earlier Great Wall with a Y motor, so the agents should have them too. Quote Link to comment Share on other sites More sharing options...
parrot Posted September 10, 2017 Report Share Posted September 10, 2017 I had a quick look on amayama. Tube with seal is about $4.50 each, so actually about the same. 11191-22010 for the tube $3.56 90430-31141 for the gasket $1.00 Quote Link to comment Share on other sites More sharing options...
philbey Posted September 11, 2017 Report Share Posted September 11, 2017 20 hours ago, altezzaclub said: Can't be worse that factory.. What's wrong with factory? I put a new set into my motor and never had a problem. Quote Link to comment Share on other sites More sharing options...
