83 corolla 3tc no spark
This winter I swapped some weber dcoe's and a header onto my 3tc swapped 83 wagon, and took out all the emissions stuff that had already been half ass deleted by the PO. it ran great before starting this project. When I went to start it in the spring, it didnt fire. I'm getting 12v to the coil, so I assumed the ICM was bad, I had an MSD 6AL lying around so I wired that up, still no spark. I get no voltage reading from either of terminals at the plug going into the distributor, with the MSD or the stock ICM. I've also tried a known good distributor, and new cap/rotor.
Before I started the carb/header swap I took the engine wiring harness out to get at things better, everything is plugged in again, besides one yellow/green wire wtih a female spade connector that goes over to the drivers side, I couldnt find anywhere to plug it in and I'm not sure if it was plugged in before.
Any ideas on what to try next? Thanks.
pic of the car when it was running
