Rolln666KE20 Posted July 16, 2018 Report Share Posted July 16, 2018 Anyone help me out for this little girl, 4 speed just doesn't cut it haha Quote Link to comment Share on other sites More sharing options...
Banjo Posted July 17, 2018 Report Share Posted July 17, 2018 (edited) That is just the sweetest looking Rolla ! Which 5 speed are you after ? The KE55 5 speed will drop in without issues, as dimenensionally it is the same as the 4 speed. The other 5 speed available is the 5 speed gearbox from a KE70,, which has the same overall dimensions, but has the point where the gear-stick comes out, a little further back. This will require cutting out your tunnel a bit, & filling the hole at the front. If you don't want to molest the floor pan/tunnel, then the KE55, 5 speed is the one to go for. Cheers Banjo Edited July 17, 2018 by Banjo Quote Link to comment Share on other sites More sharing options...
