ke20race
1974 KE20 Improved Production Race Car (Rolling Shell) and Parts
This car has competed in many Improved Production Races in NSW and QLD, It was vey competitive in the 1600cc class. Rolling shell includes
CAMS Log Book, Full CAMS approved Roll Cage, Race Rolling Shell (No engine NO Gearbox), Includes, Headlights, tail lights, park lights, headlight trims, Grille. Assembled in car is Tilton Adjustable Pedal box with remote cable adjuster, adjustable front sway bar, adjustable rear pan-hard bar, Fuels systems with lift pump, Bosch motorsport EFI pump, surge tank, wiring harness for Motec engine management system
$2500.00
Parts Available
Diff TA23 Celica housing, modified to sit on KE20 leaf springs.  Toyota Racing Development (TRD) 4-pinion clutch-type LSD centre, It runs tapered roller bearings, discs, larger Corona callipers, with custom mounts and brackets to suit KE20.  Endless race pads, 4.875:1 (6.7inch) crown wheel and pinion set.
$1500.00
4AGE Parts
1 x Set TRD USA Formula Atlantic Race H-Beam Conrods $1000.00
1 x Set TRD USA Cosworth Formula Atlantic 16oz Pistons 0.005mm OS High Comp $1000.00
1 x Set TRD USA 4AGE Formula Atlantic race cams, adjustable cam gears, race valve springs $1000.00
1 x 4AGE block race prepped w/steel main cap plates $500.00
1 x 4AGE Baffled and windage sump $100.00
1 x 4AGE quad throttle body $100.00
1 x 5.5in AP Racing Clutch twin Plate $350.00
1 x 4AGE Black top stock engine $500.00
3 x 4AGE Black top head $250.00 each
2 x KE20 radiators $50.00 each
3 x 4AGE distributors $50.00 each
1 x 4AGE alternator $50.00
1 x 4AGE starter motor $50.00
1 x 4AGE standard oil pump $50.00
1 x 4AGE flywheel $50.00
2 x 4AGE Oil cooler adaptors $20.00 each
1 x 4AGE extractors to suit KE20 $150.00
1 x 4AGE short engine $300.00
1 x T50 Gear box complete and rebuilt $500.00
1 X T50 Gear box complete disassembled $250.00
2 x KONI Race shocks to suit KE20 front struts $350.00
Open to reasonable offer on complete package that will include all of the above plus lots of additional parts
PM me for more info or call 0488583550
Car is located near Liverpool NSW
Share this post
Link to post
Share on other sites
Hi mate
I'm keen on the black top engine, throttle bodies and if the flywheel is a black top I'll take it too.
Are you willing to post to VIC if I organise a courier?
I'll call you after the weekend if I don't hear back.
Ben - 04252two5831
Share this post
Link to post
