4A-Foottotheboards Posted September 13, 2018 Report Share Posted September 13, 2018 (edited) Hi I'm just browsing around Toyota cars with the Carbie 4A-F. Appreciate it is now 'old tech' but lots of miles run on them so lots of techhie info will be about here.... I post on ToyotaNation (toosavvy, Brit in Bitz!) so perhaps you guys look in on there ?? 4A-F Edited September 14, 2018 by 4A-Foottotheboards edit Quote Link to comment Share on other sites More sharing options...
4A-Foottotheboards Posted September 15, 2018 Author Report Share Posted September 15, 2018 ....... Further to the above ...... http://forum.alltracwagon.com/cgi-bin/forum/Blah.pl?v-print/m-1301874383/ This sort of thing When did anyone see such a thorough 'hop-up' on this Corolla/Carina motor ? (well, its the only one I can find!) 4A-F Quote Link to comment Share on other sites More sharing options...
4A-Foottotheboards Posted September 17, 2018 Author Report Share Posted September 17, 2018 I understand the 4A-FE (2nd gen) had greater cam lift [7.6MM] than the dimensionally identical 4A-F Carb head. Anyone ever done a scrapyard upgrade this way.... ?? 4A-F Quote Link to comment Share on other sites More sharing options...
4A-Foottotheboards Posted September 22, 2018 Author Report Share Posted September 22, 2018 I have just ordered a Vdubb t4 'centre box' exhaust to replace my std factory 'stuffer' box... It is 50mm and a resonator/straight thru. See how it sounds, eh 4A-F Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted September 22, 2018 Report Share Posted September 22, 2018 Carbs lined up to go with it?? DCOE Webers or Mikuni bike carbs? Quote Link to comment Share on other sites More sharing options...
4A-Foottotheboards Posted September 23, 2018 Author Report Share Posted September 23, 2018 (edited) 10 hours ago, altezzaclub said: Carbs lined up to go with it?? DCOE Webers or Mikuni bike carbs? I plan the 'vac mod', to release the second choke for operation all the time, but no plans for dumping the AISIN. 4A-F Edited September 23, 2018 by 4A-Foottotheboards Quote Link to comment Share on other sites More sharing options...
parrot Posted September 23, 2018 Report Share Posted September 23, 2018 I assume that’s the old “swap the spring from one side of the diaphragm to the other” trick. I’d forgotten all about that. We used to do that back in the 80’s club racing days. But soon it was a slippery slope to twin side drafts Ah the memories! 1 Quote Link to comment Share on other sites More sharing options...
parrot Posted September 23, 2018 Report Share Posted September 23, 2018 I should add, after a speed event we would swap the spring back so the second Venturi only opened as per factory, or you lose flexibility for around town driving. 1 Quote Link to comment Share on other sites More sharing options...
4A-Foottotheboards Posted September 23, 2018 Author Report Share Posted September 23, 2018 Ah, the memories .... indeed I'm running a 'timewarp' '91 Carina II ..... These cars were default taxi/pizza delivery fodder 'bitd' >> then ovalled to death! I'm not going Rat or Scene.... (I'm 61!!) Just taking advantage of a bit of swappability & OldSkool mods. When I get the bus pass I'll likely move on to Mamod steam engines. lol 4A-F Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted September 23, 2018 Report Share Posted September 23, 2018 Well, this might be your last chance! Better than sex.... 1 Quote Link to comment Share on other sites More sharing options...
4A-Foottotheboards Posted September 23, 2018 Author Report Share Posted September 23, 2018 (edited) Ha ha.... I'm up 2 speed on OZ surf scene! I know the difference between a 'woodie' and a Woodie https://goo.gl/images/mabvVV ... why do you reckon my RicePipe is for a t4 Lovely presented piece of automobilia m8 [/thumbup] Edited September 23, 2018 by 4A-Foottotheboards Quote Link to comment Share on other sites More sharing options...
4A-Foottotheboards Posted September 23, 2018 Author Report Share Posted September 23, 2018 (edited) 2 hours ago, parrot said: I should add, after a speed event we would swap the spring back so the second Venturi only opened as per factory, or you lose flexibility for around town driving. Yes, it has been commented elsewhere that the 'factory' is best for street. My plan is to 'temp/bodge' the rod lift (disabled mode) by attaching a slotted arm to the rod - not unscrewing anything on the carb body - the slot in the arm will *'bite' the rod [due to the twist force] and a strong spring hooked to the arm end. This is turn on/offable for me to run at will, or not! *beetle lift jacks use the same principle to 'walk up' the jack leg. 4A-F Edited September 23, 2018 by 4A-Foottotheboards Quote Link to comment Share on other sites More sharing options...
4A-Foottotheboards Posted September 26, 2018 Author Report Share Posted September 26, 2018 Ooofff!! ....... That is one Big Hole!! 4A-F Quote Link to comment Share on other sites More sharing options...
4A-Foottotheboards Posted October 8, 2018 Author Report Share Posted October 8, 2018 (edited) I have ordered some exhaust putty, good price + free pp, on eBay. Popped into Halfords Auto Centre and got 4x U-clamps for £1.60 each = cannot find any cheaper option on the web. I will have to form a bend/join - over the axle - so having pre formed bends, in the original part is an 'extra bonus' 4A-F Edited October 8, 2018 by 4A-Foottotheboards Quote Link to comment Share on other sites More sharing options...
4A-Foottotheboards Posted October 16, 2018 Author Report Share Posted October 16, 2018 Yeah.... Straight thru /Glasser 4A-F Quote Link to comment Share on other sites More sharing options...
