Sign in to follow this
rke_011
Looking for k-t cable bellhousing
Don't like my chances, but does anyone have a cable k-t bellhousing they would sell.. I have Hydraulic housing but would prefer not to modify for hydraulic..
Share this post
Link to post
Share on other sites
go for a holiday to Cebu Philippines and pick one up.
Maybe grab 2 or 3, and bring them back and sell them and that will pay for your trip.
Ask me for more info,
Share this post
Link to post
Why would you modify the hydraulic?
I've just switched from a cable to a hydro. I just got a brand new set of ta22 master and slave of eBay for about $80 iirc, then just made up a braided line. It's not a hard process to convert.
There's more space within the hydro bell housing so it actually allows you to run a bigger 200mm ae71/te72 etc clutch kit, as opposed to the 180mm kit designed for k-t.
Share this post
Link to post
This is my exedy hdcb clutch plate. Makes the little 3 puck k-t thing look pathetic. I'll see if I can find a pic of it.
Share this post
Link to post
Don't want to modify firewall to mount master.. And my last attempt fitting a hydro t50 in ke10 from memory the slave hit steering or something... But that was with a 4a so positioning may have been different.
What flywheel you using with the hydro? I like the idea of hydro.. But not sure if it'll work.. Plus the 10s tunnel is tiny, so t50 may not even fit.
Share this post
Link to post
K-t slave is on the other side of the bell.
You can use a liteace flywheel. I had some random 200mm k lightened flywheel that I got from Sheldon aka blown5k that had a different bolt pattern and had it re-drilled to suit. You could just do the same to any k flywheel and have the contact area re-machined to 200mm. It wouldn't cost much.
Share this post
Link to post
