devilsix Posted May 15, 2019 Report Share Posted May 15, 2019 Hello:) I'm currently building a ke25 with a 2tg turbo engine. I will use a t293 Axle from a te71gt. But This is wider then the ke25 Axle. So My question is, Do i have to run flares or will i be able to tuck some wheels under the fender? Question 2: Does anyone know if air shocks are available for This car? quation 3: Does a ke20 fuel tank fit the ke25?:) Quote Link to comment Share on other sites More sharing options...
parrot Posted May 15, 2019 Report Share Posted May 15, 2019 You either need to fit flares after major surgery on the rear guards, or get the diff narrowed. Fuel tanks are the same Quote Link to comment Share on other sites More sharing options...
