Electronic Distributor For 4k Engine
Tham
I have just bought a Nippondenso electronic
distributor from one of the salvage yards, with
a built-in ignitor.
The vacuum advance diaphragm on this unit is
a two-stage type, with two ports, one on top of
the other. The one on the stock points distributor
of course has just one port for direct connection to the
carburetor's vacuum inlet.
The salvage yard owner gave me a T-joint to connect
the single hose from the carb to both ports of this
new vacuum advance. Alternatively, he told me that
those plastic/metal splitters for hoses of aquarium air
pumps could be used. I wonder if this is the correct
method ? My usual mechanic, as well as a car wireman,
told me that only the lower port should be used and the
upper one left unused.
It also comes with what I think is a vacuum delay valve,
very similar to that show in this pic :
http://www.top-downsolutions.com/images/309050.jpg
Which port should this go to, and which side faces the
which ? Or can this be left out ?
Thanks to the very informative users in this great forum.
Edited by Tham
  • Replies 31
Thanks to the very informative uses in this great forum.
Suck and blow on it, You will soon find out which way the vacuum goes..
The one farthest out is the advance, the inner one goes to the manifold for the retard
Does that mean I should connect the hose only to the outer one and leave the inner one unused ?
Edited by Tham
Nice photographs.
Thank you.
I bought mine from U-Pull-It, in South Australia for $28.50.
It had a cap on it so the bloke didn't realise it was electronic, I guess.
Bargain!!
It had a 2 stage vacuum advance too, with a T connector, so I just dropped it in and it worked.
A.
Wow. That is a real bargain. Just M$75 here,
less than half of what I paid for it. The salvage
yard owner threw in an old electronic coil made by
Hanshin of Japan though.
I'm still using my old points coil with a resistor, as
the above coil looks really old. Wonder
if the performance will be better with
the electronic coil.
worked.
Did you connect the T-connector direct to both ports ?
Did it come with a vacuum delay advance like the one
shown in my link above, and if so, how did you connect it ?
Thanks.
Thanks.
It didn't come with a delay advance, but I removed it from a 4k engine so it could have been installed by anyone, yes the T connector just splits the vacuum from the manifold to both ports on the advance, and I just connected the wires to my existing coil and ballast resistor setup.
As I said this is the way I found it set up on the 4K in the yard and I put it on mine the same, but it is not neccessarily the correct way?
Good luck.
A.
