Jammcn07 Posted September 16, 2019 Report Share Posted September 16, 2019 Hey guys, So ive done the dirty on the front springs in my wagon, and chopped about 1 1/2 coils off to lower her a bit. Yes I did purchase lowering spring, however they changed it FA. So out came the grinder. Now or when I’m turning sharp at low speed, ie into or out of a parallel park etc. either spring dependant on the direction I’m turning gives a good “THUDDDDDD” followed by the shockwave through the car. Ive seen what the spring is doing, it’s is rotating with the turn of the wheel, the sound is when the bottom of the spring skips over the spring locator indent in the bottom spring locator plate. My my question is WHY...??? Why is the spring turning?? How to I stop this annoying and embarrassing situation!! cheers JM Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted September 17, 2019 Report Share Posted September 17, 2019 How is the top of the spring located in the plate? Is it flat at the top with a ground spring or a cut spring in a locator on the plate. What's happening is that the top of the spring is being forced to stay with the turret mount, so it seems the top bearing is not working or the top plate is jammed. The strut, the spring and the top mount should all rotate easily together. Got photos? 1 Quote Link to comment Share on other sites More sharing options...
Jammcn07 Posted September 17, 2019 Author Report Share Posted September 17, 2019 Ill pull the whole lot out again in the weekend, take some photos and have a look at the top of the spring in relation to its position. I was only concentrated on the bottom. I'm thinking somehow the top plate it jammed. Ill come back with Pics once its all out, Cheers Quote Link to comment Share on other sites More sharing options...
