parrot Posted June 26, 2020 Report Share Posted June 26, 2020 As above, coming up as available only means they aren’t definitely unavailable! But fingers crossed. Do let us know the outcome either way. I’ll do the same with the strut tops. Quote Link to comment Share on other sites More sharing options...
wenisman Posted June 26, 2020 Report Share Posted June 26, 2020 Otherwise i was looking at something like the datsun 1200 wagon which has similar windows. ive seen replacement rubbers for those and so just trying to find out if its a roughly equal size. then i might be able to make them fit, but a direct replacement would be better. SO maybe ill keep up with toyota heritage and see what they come up with too Quote Link to comment Share on other sites More sharing options...
parrot Posted June 26, 2020 Report Share Posted June 26, 2020 (edited) Glass is glass, although it can vary in thickness. And a seam is a seam. Any other older style car with a fixed window is going to have a seal with the same construction. As long as it is long enough, it could be cut down. Amayama have come back to say they are checking stock for the strut tops and a couple of other items I ordered. Experience suggests some items will be NLA, while some others will be. Knowing my luck, only the lower control arm bolts will be available....... I should say, Toyota Heritage are a great business. Gary is very responsive to filling demand, but tooling up suppliers for his products is probably far more complex than we realise. Edited June 26, 2020 by parrot Toyota Heritage Quote Link to comment Share on other sites More sharing options...
k3twent Posted June 27, 2020 Author Report Share Posted June 27, 2020 On 6/26/2020 at 2:21 PM, parrot said: Part Number for KE2x strut tops is 48609-12030 To my surprise it is showing on Amayama as available, which really only means it MIGHT be available. Anyway, I’ve ordered a set and will find out one way or the other. $190 a pair. Rock Auto showing $19.95 each for economy quality and $55 each for daily driver. I won’t be driving my car more than once or twice a month so I’m thinking getting economy but what do you all think? I’m I wasting my money and effort getting economy? Has anyone used them before? Any regrettable experiences? Thank you all Quote Link to comment Share on other sites More sharing options...
parrot Posted June 27, 2020 Report Share Posted June 27, 2020 Be warned that part number is for a KE70/AE71/TE72 or Tercel. Will it fit a KE20? I have no idea. With respect to your question though, the daily driver item notes: The Shock/Strut mounting is exposed to strong demands and influences of the weather and therefore it is among the commonly replaced wear and tear parts. The consequences of a defect are perceptible: Loss of exact wheel control Loss of optimal road contact of the tires Unprecise steering behavior Prolongation of braking distance Increased noise Decreased absorption of vibrations Which one would you choose? I once ended up in the middle of a freeway jammed on the end of a barrier rail after an aftermarket tierod end failed. My wife to be ended up in hospital with a jaw fracture. We were very lucky. I always try and buy genuine for something like this if i can. Or think ery hard about aftermarket if it isn't Quote Link to comment Share on other sites More sharing options...
Banjo Posted June 27, 2020 Report Share Posted June 27, 2020 Here is another source of genuine Toyota KE20 strut tops, if the Amayama option doesn't play out. https://toyotaparts.mcgeorgetoyota.com/oem-parts/toyota-support-sub-assy-fr-4860912030 Cheers Banjo Quote Link to comment Share on other sites More sharing options...
k3twent Posted June 27, 2020 Author Report Share Posted June 27, 2020 35 minutes ago, Banjo said: Here is another source of genuine Toyota KE20 strut tops, if the Amayama option doesn't play out. https://toyotaparts.mcgeorgetoyota.com/oem-parts/toyota-support-sub-assy-fr-4860912030 Cheers Banjo These ones on eBay item location Thailand any good? $150 posted for the pair Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted June 28, 2020 Report Share Posted June 28, 2020 "Be warned that part number is for a KE70/AE71/TE72 or Tercel. Will it fit a KE20? I have no idea. " I would say KE70/AE71 don't fit any other KE, they have a strange assymetrical hole pattern in the 3 studs at the top. Measure the distances between the 3 holes and see if they are the same, older Toyotas tend to be, but KE70s aren't. They're 111mm, 106 & 116 to the outside of the studs in each case. Quote Link to comment Share on other sites More sharing options...
coln72 Posted June 28, 2020 Report Share Posted June 28, 2020 From memory, ke20 are a we bit different to Ke30. Cracked a pair in the KE20 club car and only had Ke30 ones in the shed. Had to enlarge the top of the strut tower and relocate 1 stud a pooftenth to make them fit. Quote Link to comment Share on other sites More sharing options...
k3twent Posted June 29, 2020 Author Report Share Posted June 29, 2020 Thanks all for your information. Seems the ones rockauto listing for a ke20 are wrong ones. Glad I asked the question otherwise I would have just gone and bought. My first time restoring a car so I guess I’ll make lots of mistakes along the way. Quote Link to comment Share on other sites More sharing options...
parrot Posted June 30, 2020 Report Share Posted June 30, 2020 The big part wholesalers can be a good source but unfortunately the catalogues can prove pretty generic, especially with older models. The Thai ebay guys are usually on the money with the right part, but some of their stuff can be a bit generic too, for example the door locks. They sort of fit, but not very well as tey use the same one across multiple models. And quality can be variable. I think an issue with some of the aftermarket strut tops is that people put them in cars with rock hard springs, then wonder why the rubber in the strut mount splits. Essentially something has to give. Amayama have come back to me saying, "We haven't heard back from the supplier regarding availability of your order #123456 however there's a 95% chance they are in stock at the supplier. Please, make payment to process the order." Not quite the usual service i expect from them, but it's been a while since I bought anything through them. I'll pay for it and see what happens. Previously they ascertained whether it was available and THEN you paid. Have also ordered some rear spring insulator pads and some control arm bolts. Quote Link to comment Share on other sites More sharing options...
wenisman Posted July 1, 2020 Report Share Posted July 1, 2020 I just had the same experience with amayama. They couldn't confirm the frame number, so I sent them pics of the chassis plate. Then they asked for payment but haven't confirmed of they can get them yet However apparently the seals I want are in stock, so I've paid and will have to wait and see. Quote Link to comment Share on other sites More sharing options...
parrot Posted July 3, 2020 Report Share Posted July 3, 2020 So no surprise, the genuine KE2x strut tops are out of production and unavailable. Not very happy with the service from Amayama on this occasion, and that's got nothing to do with the unavailability of the part, rather their requirement for payment 3 days ago without any certainty of part availability. Quote Link to comment Share on other sites More sharing options...
k3twent Posted July 3, 2020 Author Report Share Posted July 3, 2020 What car club you all recommend? I have emailed tccav but want to look into a few others. Something not as big Quote Link to comment Share on other sites More sharing options...
parrot Posted July 3, 2020 Report Share Posted July 3, 2020 TCCAV is great, but Victorian based obviously. Where are you? They are still a very social group with an active competition programme, plus club meetings when COVID doesn't get in the way. As with any group, there is a smaller core of active members, so don't be put off by thoughts the group is too big, many of those (including me) are remote and not directly involved in the internet era. Quote Link to comment Share on other sites More sharing options...
