davek_14 Posted September 9, 2020 Report Share Posted September 9, 2020 Hi all, I am currently installing a 7K carby engine in the ke30. Just wanted to share my thoughts on the progress so far as it might help others. Got a 7K engine from melbourne and we have rebuilt it completely including a new flywheel and HD clutch kit ( 4K flywheel and clutch and a spigot bearing rsb 508) Used the 4K sump to get the measurements to cut the 7K sump. Cut the sump completely just below where it mates to the block and then cut 20 mm off the sump all the way round. Rewelded sump. Used the 4K oil pump as 7K one is too long in the modified sump. Did a trial install in the engine bay and it fits perfectly using the original engine mounts from the 7K engine. The left hand lower mount for the gearbox from the 4K needs to be massaged a bit to fit the 7K block but the drivers side fits perfectly. Using the 7K starter motor and the 4K alternator, also the 4K fuel pump and distributor. Using the 7K inlet manifold as it is a better design than the 4K one and a set of headers.Also a 32/36 Weber rejetted for the 7K engine. That’s about it for the moment, currently stripping the body paint and getting the car ready for a full 2pack repaint. Will update with photos as we proceed. Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted September 9, 2020 Report Share Posted September 9, 2020 Sounds good! An easy car to drive & you'll never be short of torque. It will be interesting to see if a better diff is a 3.9 than 4.3. Quote Link to comment Share on other sites More sharing options...
Jono.C Posted September 20, 2020 Report Share Posted September 20, 2020 Whats the reason for using the 4k distributor? The 7k one is electronic and a better unit Quote Link to comment Share on other sites More sharing options...
davek_14 Posted October 8, 2020 Author Report Share Posted October 8, 2020 Just wanted to get it going. Haven’t checked the 7K dissy, assume its an internal igniter one and only needs a suitable coil to run, anyone got an answer for me on that. Quote Link to comment Share on other sites More sharing options...
Banjo Posted October 8, 2020 Report Share Posted October 8, 2020 (edited) Hi Dave, There was a good discussion about this subject, here on Rollaclub, some (10) years ago. https://www.rollaclub.com/board/topic/42941-how-to-wire-a-5k-electronic-distributor/ The Yellow Bible (Toyota factory Manual) advises that the total primary resistance, should be about 1.9 ohms. Just don't use one of the very low ohm hi energy coils, or you run the risk of burning out the inbuilt ignitor in the dizzy. I've run a coil with 1.6 ohm primary for many years, with my 5K electronic dizzy, & never had an issue. Even if you do lose an ignitor, don't throw away the dizzy, as it is a simple job, to remove the ignitor, & bring the variable Reluctance (VR) two (2) wires out, & feed into a Bosch external ignitor, (P/N BIM024) designed for VR triggering. Actually, there was a good how-to on Toymods, on this subject at https://www.toymods.org.au/forums/threads/24609-Converting-to-a-Bosch-Ignition-Module-(Reluctor-Dizzys) Cheers Banjo Edited October 9, 2020 by Banjo Quote Link to comment Share on other sites More sharing options...
davek_14 Posted October 9, 2020 Author Report Share Posted October 9, 2020 Thanks Banjo, just what I needed, guessing the 7K distributor is the same as the 5k. This is all new to me, old school points dissy is where I am atm. Old holdens and now my dads ke30 to bring into the world again. Cheers Dave. Quote Link to comment Share on other sites More sharing options...
Banjo Posted October 9, 2020 Report Share Posted October 9, 2020 I think the 7K dizzy body was slightly larger in diameter, than the one for the 5K, but the ignitor & VR sensor are the same. Both engines made for commercial vehicles, so the advance / retard curves would be very similar. http://jp-carparts.com/toyota/partlist.php?maker=toyota&type=651150&cartype=100&fig=1902 I think I might have a 7K body floating around in the shed. I'll take a look. Toyota used both Bosch & Denso dizzies, & the Bosch was the bigger of the two. If your dizzy is cactus, don't throw it away. Fit an Accuspark Hall trigger / ignitor pack, & you'll have a great setup. Good idea, to strip out the mounting plate, inside the dizzy first, & see what state the centifugal advance bob weights & springs are in. Cheers Banjo Quote Link to comment Share on other sites More sharing options...
davek_14 Posted October 10, 2020 Author Report Share Posted October 10, 2020 Thanks Banjo, you have been very helpful with all this. I have searched through all the bits that came with the engine but couldn’t find the coil, can get one from the wreckers but probably just use a Bosch coil as long as it is around 1.9 ohms as you suggested. Cheers and thanks for your very helpful advice. Dave. body back to bare metal rust repaired, panels all smoothed and ready for 2 pack. Quote Link to comment Share on other sites More sharing options...
davek_14 Posted October 10, 2020 Author Report Share Posted October 10, 2020 Quote Link to comment Share on other sites More sharing options...
davek_14 Posted October 10, 2020 Author Report Share Posted October 10, 2020 Banjo, I found the distributor in the bag of bits the mechanic stripped off the engine for the rebuild. It’s a denso one, but has these weird connectors on dissy cap and high tension lead to the coil. So guessing I will have to find a coil from a townace I order to get it working. Quote Link to comment Share on other sites More sharing options...
Jono.C Posted October 16, 2020 Report Share Posted October 16, 2020 I bought a distributor cap off a km36 liteace with a 5k engine. Distributor cap is same size but runs conventional 4k style plug leads etc Quote Link to comment Share on other sites More sharing options...
davek_14 Posted October 22, 2020 Author Report Share Posted October 22, 2020 Thanks Jono, will look into that ASAP. Quote Link to comment Share on other sites More sharing options...
