RAT_SECA Posted April 25, 2021 Report Share Posted April 25, 2021 Hi guys and girls, thought I would post up my new project that I have been planning for quite a while. Have had the 4AGE donor car for over a year now but have been searching for the perfect car to chuck all the good bits into! So here is the one I found. I am the 3rd owner, 157,xxxkms on the clock. Paint is near perfect apart from fade on the roof which will be being resprayed factory colour. Jacked it up to have a look underneath and found NO RUST! So before I pulled the 4AGE out I decided to comp test it, in which, no joke it lost compression on cylinders 1-3 while I was testing it.... All had 30psi except cyl 4 which had 140psi. So plan is to rebuild it, I pulled the head off on the weekend and couldn't see any obvious signs as to why it lost comp. Will be dropping the head off at the machiners tomorrow to have it pressure tested. I also picked up a RV Seca which will donate it's 255mm front brakes and 243mm rear disc brake conversion. Will be a whole new car when it is done! Plan is to keep it relatively stock on the outside. Just want a clean weekender. Here's some photos for you all! Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted April 26, 2021 Report Share Posted April 26, 2021 " So before I pulled the 4AGE out I decided to comp test it, in which, no joke it lost compression on cylinders 1-3 while I was testing it.... All had 30psi except cyl 4 which had 140psi. So plan is to rebuild it, I pulled the head off on the weekend and couldn't see any obvious signs as to why it lost comp. " That's fascinating! I can't see it being a head gasket or a crack, which doesn't leave much except valves sticking open from not being used, or a fault with the meter. Its possible rings broke in those cylinders if they were glued up from sitting. Make sure to tell us what caused it. Otherwise, the Corolla looks excellent, and the background looks Queenslandish, so rust-free is surprising. Quote Link to comment Share on other sites More sharing options...
LittleRedSpirit Posted May 2, 2021 Report Share Posted May 2, 2021 Sounds like a fun little project. Did you dribble a couple ml of oil into each cylinder to try to lube up any stuck rings while comp testing? Quote Link to comment Share on other sites More sharing options...
RAT_SECA Posted June 26, 2021 Author Report Share Posted June 26, 2021 Some updates for ya'll, ended up having the head reconditioned, so now I am rebuilding the bottom end as well. Got genuine water pump, oil pump and gasket kit ready for it. Still got a fair bit to do as well. Also put the full Series 1 SX interior in. Stock SX Also chucked the wheels off the RV Seca on. Found out they are actually Rota branded wheels. And got the engine and dash harness out the SX along with the long dash cluster. Will be waiting for the 4AGE to be done before I go pulling the sedan apart so it's still drivable until then. Quote Link to comment Share on other sites More sharing options...
RAT_SECA Posted August 14, 2021 Author Report Share Posted August 14, 2021 (edited) Bit of an update. Have decided to go with my original plan and build a 7AGE. So will be ordering most of the parts I need in the next few months from MRP. But for now this is where I am at. Have just completed the brake swap. Out with the 238mm solid front end and drum rear end, in with the 258mm vented front end with swaybar and 242mm disc brake rear end. After the motor is done I will be pulling it back apart to replace all the bushes and brakes. But for now I need to get the parts cars out of here hence swapping it over now. Old New Will have to give her a wash soon, starting to look a bit like a barn find. Edited August 14, 2021 by RAT_SECA Quote Link to comment Share on other sites More sharing options...
RAT_SECA Posted July 23, 2022 Author Report Share Posted July 23, 2022 (edited) Big update on this car, bit of a change of plans. It has now become my daily driver. In saying that the mods have not stopped and mods are still incoming as well including some goodies from japan! Chucked in the AE93 SX cluster while keeping the original low km odometer. Cleaned up the engine bay and polished the valve cover. And just a few shots of the old girl! Edited July 24, 2022 by RAT_SECA Fixed photos Quote Link to comment Share on other sites More sharing options...
RAT_SECA Posted July 24, 2022 Author Report Share Posted July 24, 2022 Photos should be working now! Quote Link to comment Share on other sites More sharing options...
RAT_SECA Posted September 1, 2022 Author Report Share Posted September 1, 2022 (edited) Few mods over the past few weeks! JDM Wagon face front end conversion! And now sitting pretty on some BC coilovers! Missed the low life so much! And black slimline weather shields! And wheels have been ordered but have a 4-6 month wait! Edited September 3, 2022 by RAT_SECA Photos fixed Quote Link to comment Share on other sites More sharing options...
Ridwan Posted September 25, 2022 Report Share Posted September 25, 2022 @RAT_SECA do you have the wiring diagram for the long cluster ? I'm planning upgrade mine with the long cluster but I don't have the wiring diagram ... thanks Quote Link to comment Share on other sites More sharing options...
RAT_SECA Posted November 3, 2022 Author Report Share Posted November 3, 2022 On 9/25/2022 at 2:54 PM, Ridwan said: @RAT_SECA do you have the wiring diagram for the long cluster ? I'm planning upgrade mine with the long cluster but I don't have the wiring diagram ... thanks Hi mate I used this one! Quote Link to comment Share on other sites More sharing options...
ke70dave Posted November 3, 2022 Report Share Posted November 3, 2022 Those lights are certainly unique! where did you get them? Quote Link to comment Share on other sites More sharing options...
RAT_SECA Posted May 9, 2023 Author Report Share Posted May 9, 2023 Well I haven't posted here for a while. Fair amount of work gone into it since last post. Now on some 16x8 +15 Work Seeker CX wheels! Fitted front strut brace and inner fender braces. And fitted Series 1 SX front bumper with factory lip. Quote Link to comment Share on other sites More sharing options...
