Ethan.ke20 Posted September 24, 2021 Report Share Posted September 24, 2021 Hey guys Just wondering if there’s a difference between ke20 lower control arms and te27 lower control arms? wanting to run the te27 gtx2 T3 lca and caster arm kit on my ke20 cheers Quote Link to comment Share on other sites More sharing options...
parrot Posted September 28, 2021 Report Share Posted September 28, 2021 Control arms are the same 1 Quote Link to comment Share on other sites More sharing options...
Ethan.ke20 Posted October 2, 2021 Author Report Share Posted October 2, 2021 Are they basically the same car? (Other than engine and body shape and some interior) Know if the brake kits that are made for the te27 fit a ke20? Quote Link to comment Share on other sites More sharing options...
parrot Posted October 3, 2021 Report Share Posted October 3, 2021 TE27 struts, brakes and steering arms are different from ke20. As are the engine crossmember, tailshaft and rear diff, if that is relevant to what you are thinking. There are myriad other smaller differences. 1 Quote Link to comment Share on other sites More sharing options...
Ethan.ke20 Posted October 3, 2021 Author Report Share Posted October 3, 2021 (edited) Thanks mate would be a lot easier if T3 made more ke20 products/gear haha Edited October 3, 2021 by Ethan.ke20 Quote Link to comment Share on other sites More sharing options...
parrot Posted October 3, 2021 Report Share Posted October 3, 2021 Well they are US based and KE20 is rare over there. Realistically you need to upgrade to coilovers from something else- often AE86, and go to a TE27 85mm spaced steering arm to fit them (T3 do those too, factory are rare and very expensive). The ball joint pin is smaller than everything post KE20 so you can’t really use a later factory steering arm. Then you can access better brake, strut insert options and have larger bearings etc 1 Quote Link to comment Share on other sites More sharing options...
