Relays
Revision as of 02:51, 1 October 2006 by MedicineMan (talk | contribs)
Relays
A relay is used to control a high-current circuit with a low-current signal, as in the starter solenoid of your motor. They are a simple electromechanical switch made up of an electromagnet and a set of contacts. They can be broken down into 2 circuits (A control circuit and a load circuit). The control circuit is the side with the coil and the load circuit is the side with the switch. When a current flows through the coil, the resulting magnetic field attracts an armature that is mechanically linked to a moving contact. The movement either makes or breaks a connection with a fixed contact.
Circuit Opening Relay Wiring
Standard Relay Wiring
For more information on relays follow the link below.
http://www.autoshop101.com/forms/hweb2.pdf
Article by Medicine_Man
