Tech:Engine/A Series/Converting to RWD
Revision as of 01:22, 9 June 2005 by MedicineMan (talk | contribs)
Crossmembers
Engine Crossmember - You can use the engine crossmember from an AE71/AE86 as the engine mounts will bolt straight up. If you have a KE70 crossmember, you will have to get custom engine mounts made.
Engine Mounts
You can use the engine mounts from an AE71/AE86 4A-C engine or have some custom made. Realise that custom made engine mounts require engineering.
Flywheel / Clutch / Pressure Plate / Throwout Bearing
There are 2 different size 4AGE flywheels, for 200mm and 212mm clutches. If yours is the 200mm clutch, just buy an AE71/AE86 200mm clutch kit. If yours is the 212mm Clutch, you will have to buy an AE92 100KW 4AGE 212mm clutch kit (also you will have to buy a throwout bearing from an AE86, as the AE92 clutch kit throwout bearing is completely different).
Spigot Bearing
FF / MR mount 4AGE engines do not have a spigot bearing in the crankshaft. You can press a spigot bearing from an AE71/AE86 4A-C into the crankshaft.
Gearbox
There are 2 main options for a gearbox
ADM T50 (Australian Domestic Market) - Clutch fork on passenger side of car. JDM T50 (Japanese Domestic Market) - Clutch fork on drivers side of car.
W5x Gearbox - You can use a W5x gearbox with a bellhousing adapter, people usually swap to these when their engines are putting out high power figures as T50 gearboxes are a lot weaker.
Tailshaft
Intake
Exhaust
