Tech:Engine/S Series/Blocks
Revision as of 06:47, 21 December 2007 by Robj (talk | contribs)
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
Engine
Code
Power
       Stats
KW ----------- NM
Build
Dates
Capacity
(cc)
Induction
Comp
Ratio
Bore
Diameter
Piston
Length
Rings
Pins
Power
Torque
Oil
Comp
Dia
Len
1S LU
66
1832
Carb
80.5 mm
68 mm
1 x 40 mm
2 x 1.5 mm
20 mm
66 mm
1S iLU 66 ? 1832 SPi * ? 80.5 mm 68 mm 1 x 40 mm 2 x 1.5 mm 20 mm 66 mm
2S 1995 Carb 84.0 mm 90.0 mm
2S-E 1995 EFI 9.8:1 84.0 mm 90.0 mm
3S-FE 1998 EFI 9.5:1 86.0 mm 86.0 mm
3S-GE Gen 1 1985-1990 1998 EFI 86.0 mm 86.0 mm
3S-GE Gen 2 1998 EFI 86.0 mm 86.0 mm
3S-GE Gen 3 1998 EFI 86.0 mm 86.0 mm
3S-GE Gen 4 1998 EFI 86.0 mm 86.0 mm
3S-GE Gen 5 1998 EFI 86.0 mm 86.0 mm
3S-GTE Gen 1 1998 Turbo 86.0 mm 86.0 mm
3S-GTE Gen 2 1998 Turbo 86.0 mm 86.0 mm
3S-GTE Gen 3 1998 Turbo 86.0 mm 86.0 mm
4S-FE 1838 EFI 82.5 mm 86.0 mm
4S-FiE 1838 SPi 82.5 mm 86.0 mm
5S-FE Gen 1 1989-1994 2163 EFI
5S-FE Gen 2 2163 EFI
1SC
1S-L(U)
1S-ILU
Notes : The 1S-ILU came with Single Point Injection
  • ST150 Carina (1985 - 1987) Europe
2S-C
* ST141 Corona (1983?-1985?)
*SA64 Celica (????-????)
2S-E
* SV1? Camry (1983-1986)
* S??? Corona
3S-FE
SV21 Camry (?-?)
3S-GE
Gen1
* ST162 Celica? (?-?)
Gen2 3S-GE:
*ST185 Celicas (?-?)
*SW20 MR2 (1991-199?)
Gen3 3S-GE:
* Celica ST202 USA? (????-????)
Gen4 3S-GE "Beams": (Single-VVTi "Redtop")
* SW20 MR2 (1998) Only ~1000 Beams MR2's produced
Gen4 3S-GE "Beams": (Twin-VVTi "Blacktop")
* SXE10 Lexus IS200 (????-????)
Gen 1 3S-GTE:
* ST165 GT4 Celica (1988-1989)
Gen 2 3S-GTE:
* ST185 GT4 Celica (1990-1993)
* SW20 MR2 (1990-199X?)
Gen 3 3S-GTE:
* ST205 GT4 Celica (1994-1999)
* ST246 4WD Caldina (NZ, Japan) (?-?)
Gen 1 5S-FE: 2.2 Litre Inline 4 EFI
* ST184 Celica (1990-1993)
Gen 2 5S-FE: 2.2 Litre Inline 4 EFI
* ST204 Celica (1994-1999)
