Tech:Engine/S Series/Converting to RWD
Jump to navigation
Jump to search
Converting S-Series engines to RWD can be done.
List of things that you might want to consider
- Engine Mounts and Crossmembers
- Rear Wheel Drive Gearbox and Bellhousing Configuration
- Flywheel, Clutch and Starter
- Sump (oil pickup) and Windage Tray Configuration
- Fuel Pump and Fuel Lines
- Wiring Harness and Pinouts for Aftermarket ECUs
More to come...
In my conversion, also custom inlet manifold, custom exhaust manifold. Some blocks have different mounting points on the block. (Series 2 MR2 was good for me in the KE25 corolla).
Issues around distributor cap pointing out the back of the head, ito firewall. I used an aftermarket computer, so didn't need the distributor, only the pickup inside it.
