Tech:Engine/A Series/Converting to RWD
Engine Crossmember - You can use the engine crossmember from an AE71/AE86 as the engine mounts will bolt straight up. If you have a KE70 crossmember, you will have to get custom engine mounts made.
You can use the engine mounts from an AE71/AE86 4A-C engine or have some custom made. Realise that custom made engine mounts require engineering.
Flywheel / Clutch / Pressure Plate / Throwout Bearing
There are 2 different size 4AGE flywheels, for 200mm and 212mm clutches. If yours is the 200mm clutch, just buy an AE71/AE86 200mm clutch kit. If yours is the 212mm Clutch, you will have to buy an AE92 100KW 4AGE 212mm clutch kit (also you will have to buy a throwout bearing from an AE86, as the AE92 clutch kit throwout bearing is completely different). Apparently the 212mm clutch will get better grip as it has more surface area.
There are 2 main options for a gearbox
Clutch Master / Slave Cylinders
Article by Medicine_Man
Back to A Series Engines
