Tech:Engine/A Series/Converting to RWD
Revision as of 05:11, 27 January 2008 by MedicineMan (talk | contribs)
Crossmembers;
Engine Crossmember - You can use the engine crossmember from an AE71/AE86 as the engine mounts will bolt straight up. If you have a KE70 crossmember, you will have to get custom engine mounts made. (See http://www.rollaclub.com/faq/index.php?title=Tech:Engine/A_Series/Crossmembers for comparison of KE70 and AE71 crossmembers).
Engine Mounts;
You can use the engine mounts from an AE71/AE86 4A-C engine or have some custom made. Realise that custom made engine mounts require engineering.
Flywheel / Clutch / Pressure Plate / Throwout Bearing;
There are 2 different size 4AGE flywheels, for 200mm and 212mm clutches. If yours is the 200mm clutch, just buy an AE71/AE86 200mm clutch kit. If yours is the 212mm Clutch, you will have to buy an AE92 100KW 4AGE 212mm clutch kit (also you will have to buy a throwout bearing from an AE86, as the AE92 clutch kit throwout bearing is completely different). Apparently the 212mm clutch will get better grip as it has more surface area.
Spigot/Pilot Bearing;
Gearbox;
There are 2 main options for a gearbox
Clutch Master / Slave Cylinders;
Tailshaft;
Intake Manifolds;
Cooling System;
Article by Medicine_Man
Back to A Series Engines
Rollaclub
