Tech:Engine/A Series/Converting to RWD
Revision as of 05:22, 27 January 2008 by MedicineMan (talk | contribs)
Engine/Gearbox Crossmembers;
Engine/Gearbox Mounts;
You can use the engine/gearbox mounts from an AE71/AE86 4A-C engine or have some custom made. (Custom made engine/gearbox mounts will require engineering). The rubber mounts can still be bought new from TRD and Cusco.
Flywheel / Clutch / Pressure Plate / Throwout Bearing;
There are 2 different size 4AGE flywheels, for 200mm and 212mm clutches (Sometimes the 212mm clutch is referred to as 215mm). If yours is the 200mm clutch, just buy an AE71/AE86 200mm clutch kit. If yours is the 212mm Clutch, you will have to buy an AE92 100KW 4AGE 212mm clutch kit (also you will have to buy a throwout bearing from an AE71/AE86, as the AE92 clutch kit throwout bearing is completely different). Apparently the 212mm clutch will get better grip as it has more surface area.
Spigot/Pilot Bearing;
Gearbox;
There are 2 main options for a gearbox. The standard T50 is good for N/A and some low power Boosted setups, Though if you are chasing high power you will want to go with a W5x series gearbox.
Clutch Master / Slave Cylinders;
Tailshaft;
Intake Manifolds;
Quad Throttle Bodies - Nothing beats the sounds of quad throttle bodies, its a good way to go if you want a tough N/A engine. These can be found on the 20 valve variant of the 4AGE.
Cooling System;
Article by Medicine_Man
Back to A Series Engines
Rollaclub
