Tech:Engine/K Series/Intake manifolds
Revision as of 14:28, 27 December 2010 by Towe001 (talk | contribs)
Intake manifolds for 3k / 4k
From what I know there are basically 4 different OME inlet manifolds for a 3/4 k that support single carby. Bigport (30mm) with bent runners. (Runners shrink in size in between head and plenum) Bigport (30mm) with straight runners. (Runners stay consistent in size and feed 2 to 1 then 2 to plenum) Mid port (27mm) with bent runners. (Runners stay consistent in size and feed 4 to 1) Small port (25mm) with bents runners. (stock) The bigport with straight runner has other issues, It's plenum area is small you could hog this out, and it does not support a dual exhaust manifold so any HP gains in the inlet will be lost in the exhaust, you could get around the exhaust issue with extractors.
Here's some pix to tell the story.
Common small port as we all know and love.
caption
Midport I suspect these are on 4k and later but now sure.
caption
Common bigport.
caption
Early biport I think.
caption
Bigport straight plenum area.
caption
Bigport straight runner sizes.
caption
Bigport straight note exhaust triangle is 180 deg out.
caption
Bigport straight exhaust manafold.
caption
Taken from http://www.rollaclub.com/board/topic/44925-bigport-manifolds-for-3k/page__view__findpost__p__468972
Article by Andy43 / Towe001
Back to K Series
Rollaclub
