Tech:Engine/K-Series/TRD
Jump to navigation
Jump to search
Link by Taz_Rx
Transcription
Stage I
(1) Main modifications
- a. Cylinder head gasket.
- b. Piston
- Without altering the displacement (75Ø 1,166cc), the compression ratio has been incrased.
- c. Piston rings.
(2) Required parts.
| Description | Qty. |
| Gasket,cylinder head | 1 |
| Ring set, piston | 4 |
| Piston w/pin | 4 |
