Tech:Engine/K-Series/TRD
Revision as of 03:46, 16 September 2012 by Irokin (talk | contribs) (→‎Stage I)
Link by Taz_Rx
Transcription
Stage I
(1) Main modifications
a. Cylinder head gasket.
b. Piston
c. Piston rings.
(2) Required parts.
Description Qty.
Gasket,cylinder head 1
Ring set, piston 4
Piston w/pin 4
(3) Assembling standards.
Item Sports parts S. T. D
No. 1 No.2 No.1 No.2
Stage II
1. PISTON & PISTON RINGS
(1) Main modifications.
a. Piston
b. Piston rings
(2) Required parts.
Description Qty.
Ring set, piston 4
Piston w/pin 4
2. VALVE MECHANISM
a. Camshaft
b. Valves
c. Valve springs.
(2) Required parts.
1 13511-KE003 Camshaft rowspan="2" Either one Overlap 70°
2 Valve, intake | 4 | Head dia. 37∅
3 Valve, exhaust | 4 | Head dia. 30∅
90501-42409 | Spring, compression (outer) | 8 | "O"
