Tech:Engine/K-Series/TRD
Jump to navigation
Jump to search
Link by Taz_Rx
Transcription
Stage I
(1) Main modifications
- a. Cylinder head gasket.
- b. Piston
- c. Piston rings.
(2) Required parts.
| Description | Qty. |
| Gasket,cylinder head | 1 |
| Ring set, piston | 4 |
| Piston w/pin | 4 |
(3) Assembling standards.
Stage II
1. PISTON & PISTON RINGS
(1) Main modifications.
- a. Piston
- b. Piston rings
(2) Required parts.
| Piston w/pin | 4 |
2. VALVE MECHANISM
- a. Camshaft
- b. Valves
- c. Valve springs.
(2) Required parts.
