Tech:Engine/K-Series/TRD
Link by Taz_Rx
Transcription
Stage I
(1) Main modifications
a. Cylinder head gasket.
b. Piston
c. Piston rings.
(2) Required parts.
Description Qty.
Gasket,cylinder head 1
Ring set, piston 4
Piston w/pin 4
(3) Assembling standards.
Item Sports parts S. T. D
No. 1 No.2 No.1 No.2
Stage II
1. PISTON & PISTON RINGS
(1) Main modifications.
a. Piston
b. Piston rings
(2) Required parts.
Description Qty.
Ring set, piston 4
Piston w/pin 4
2. VALVE MECHANISM
a. Camshaft
b. Valves
c. Valve springs.
(2) Required parts.
Replace with the above parts.
3. INTAKE & EXHAUST SYSTEMS
a. Intake manifold.
b. Exhaust manifold.
(2) Required parts.
(3) Assembling procedures.
a. Carburetor.
b. Accelerator linkage.
(2) Required parts.
STAGE III
1. CYLINDER HEAD
Item Detail Size & etc.
Valve seat ring (IN.) "
Valve seat ring (EX.) "
Caution
At the same time with the modification of the cylinder head, perform the surface grinding of the cylinder block top surface.
(Refer to cylinder block paragraph.)
(2) Required Parts.
1 Head assy, cylinder
8 90116-KE001 Bolt, stud 2
9 90116-KE002 Bolt, stud 6
Caution
Caution
Contact surface angle 45°
Exhaust mm 1.2 +0.2 -0
d. Port grinding.
Intake.
Exhaust.
Combustion chamber capacity
As a unit - 22 ~ 23 cc
When assembled - 31 cc
f. Water jacket machining.
Caution
2. CYLINDER BLOCK
(2) Required part.
a. Surface grinding.
Cylinder block top surface
Warpage allowance - 0.02 mm
b. Boring.
Caution
3. PISTON & PISTON RINGS
a. Piston
b. Piston rings.
c. Piston pin.
(2) Required parts.
2 13011-KE006 Piston w/pin 4
List 8
Item Sports parts
Piston standard diameter mm
78.96 +0.02
-0
piston clearance mm 0.07~0.10
c. Piston pin.
List 9
Item Sports parts
Piston pin bore mm
20 +0.012
-0
Piston pin outer diameter
20 +0.017
+0.005
Caution
d. Piston rings.
List 10
Compression
ring
No. 1 No.2
Caution
====(1) Main modifications.
a. Connecting rod.
b. Crankshaft.
c. Flywheel.
(2) Required parts.
a. Connecting rod.
List 11
b. Crankshaft.
List 12
Roundness limit mm 0.008 0.01
Bend limit mm 0.02 0.03
c. Flywheel.
Crankshaft x flywheel
Tightening torque - 800kg.cm
Caution
5. VALVE MECHANISM
