Tech:Engine/K-Series/TRD
Link by Taz_Rx
Transcription
People are encouraged to check any measurements or part numbers against the original manual in case of transcription errors.
Stage I
(1) Main modifications
- a. Cylinder head gasket.
- b. Piston
- c. Piston rings.
(2) Required parts.
| Description | Qty. |
| Gasket,cylinder head | 1 |
| Ring set, piston | 4 |
| Piston w/pin | 4 |
(3) Assembling standards.
Stage II
1. PISTON & PISTON RINGS
(1) Main modifications.
- a. Piston
- b. Piston rings
(2) Required parts.
| Piston w/pin | 4 |
2. VALVE MECHANISM
- a. Camshaft
- b. Valves
- c. Valve springs.
(2) Required parts.
Replace with the above parts.
3. INTAKE & EXHAUST SYSTEMS
- a. Intake manifold.
- b. Exhaust manifold.
(2) Required parts.
(3) Assembling procedures.
- a. Carburetor.
- b. Accelerator linkage.
(2) Required parts.
STAGE III
1. CYLINDER HEAD
- Caution
(2) Required Parts.
- Caution
- Caution
- d. Port grinding.
- Intake.
- Exhaust.
- Combustion chamber capacity
- As a unit - 22 ~ 23 cc
- When assembled - 31 cc
- f. Water jacket machining.
- Caution
2. CYLINDER BLOCK
(2) Required part.
- a. Surface grinding.
- Cylinder block top surface
- Warpage allowance - 0.02 mm
- b. Boring.
- Caution
3. PISTON & PISTON RINGS
- a. Piston
- b. Piston rings.
- c. Piston pin.
(2) Required parts.
| Item | Sports parts | |||
- c. Piston pin.
| Piston pin bore mm |
| Piston pin outer diameter |
- Caution
- d. Piston rings.
| Compression
ring |
| No. 1 | No.2 | |||||
- Caution
====(1) Main modifications.
- a. Connecting rod.
- b. Crankshaft.
- c. Flywheel.
(2) Required parts.
- b. Crankshaft.
- c. Flywheel.
- Crankshaft x flywheel
- Caution
5. VALVE MECHANISM
- a. Camshaft.
mm |
Valve clearance
mm |
Cam top center | ||||
| A | B | C | D | E | F | |||
EX:0.38 |
106 | 109 |
EX:0.35 |
110 | 110 |
EX:0.4 |
106 | 114 |
EX:0.3 |
104 | 110 |
- b. Valves.
| IN | EX | IN | EX | |
- c. Valve springs.
| Item | Outer | Inner |
- d. Valve spring retainer.
- e. Valve stem pad.
- f. Rocker support.
- g. Rocker arm spacer
- h. Push-rod.
- i. Valve lifter.
- Reference
(2) Required parts.
| 10 | 90072-72661
90072-72681 |
Pad, retainer | 8 | "O" |
- Caution
- b. Valves
| Item | Sports parts | ||||
| Face contact width mm |
| (limit) mm | 0.08 | ||||
- Caution
- c. Rocker support.
- d. Valve lifter.
6. LUBRICATION SYSTEM
- a. Oil pump
- b. Oil pan.
- c. Oil strainer.
- d. Oil cooling system.
| 10 | Clamp | 6 | ||
| 14 | Hose, oil cooler | |||
- a. Oil pump.
- b. Oil filter.
- (Refer to Fig. 14)
- Caution
7. INTAKE & EXHAUST SYSTEMS
- c. Manifold stay.
(2) Required parts.
- c. Manifold stay.
8. FUEL SYSTEM
- a. Carburetor.
| Item | Specification |
| Small venturi | 8011-1 |
| Main jet size | 160#~200# |
| Air jet size | 180#~220# |
| Emulsion tube | ET7772-2 |
| Idle jet side | 50# |
| Pump jet size | 33#~ |
| Needle valve size | 170# |
| Fuel level height | 8.0mm |
| Air horn length | 50mm |
- b. Fuel pump & filter.
| Rated voltage | 12V | |
| Rated current | 2.3A |
(2) Required parts.
DHLA45 x 2 |
- Caution
9. ACCELERATOR LINKAGE
(2) Required part.
- a. Distributor.
| Weight kg | 0.7 | 1.1 | |
- b. Alternator pulley.
- c. Cooling system.
(2) Required parts.
- Ignition timing
(2) Required parts.
Service Standards
Cylinder Head
| Item | S. T. D | Racing specification | ||||
| Bottom surface warpage limit mm | 0.10 | 0.05 | ||||
| Valve seat | Contact surface angle | 45° | 45° | |||
| Contact surface width mm | Intake | 1.4 |
| Exhaust | 1.5 |
Cylinder Block
| Top surface warpage limit mm | 0.05 | 0.05 | |
| Valve lifter hole boremm | 20.000~20.021 | ← | |
| Cylinder | Bore mm | 75.00~75.05 | 79.03~79.08 |
| Wear limitmm | 0.2 | 0.06 | |
| Taper, roundness limitmm | 0.02 | ← | |
| Cylinder bore differencemm | 0.05 | ← | |
| Liner | Fitting allowancemm | 0.055~0.15 | ← |
| Fitting loadkg | 2000~3000 | ← | |
Piston, Piston Pin, Piston Rings
| Piston Diametermm | 74.97~75.02 | 78.96~78.98 | |
| Clearance between cylindermm | 0.03~0.05 | 0.07~0.10 | |
| Piston pin fitting temperatureC° | 70~80 | 80 | |
| Piston ring gap | Compression ring No.1 No.2 mm | 0.15~0.35 | ← |
| Oil ringmm | 0.015~0.06 | ← | |
| Clearance between ring & groove | Compression ring mm | 0.015~0.06 | 0.03~0.05 |
| Oil ring mm | 0.015~0.06 | ← | |
| Piston pin outer diametermm | 17.999~18.011 | 20.005~20.017 | |
Connecting Rod, Bearing
| Bend limit (per 100mm)mm | 0.05 | 0.05 | |
| Twist limit (per 100mm)mm | 0.15 | 0.05 | |
| Large end thrust clearance | Limit mm | 0.3 | 0.3 |
| Specified mm | 0.110~0.214 | ← | |
| Clearance between | Limit mm | 0.05 | 0.05 |
| Specified mm | 0.004~0.008 | 0.009~0.014 | |
| Bearing oil clearance pin & bore | Limit mm | 0.10 | |
| Specifiedmm | 0.024~0.048 | 0.04~0.06 | |
Crankshaft
| Bend limitmm | 0.03 | 0.02 | |
| Thrust clearance | Limitmm | 0.3 | 0.3 |
| Specifiedmm | 0.04~0.222 | 0.06~0.15 | |
| Taper, roundness limitmm | Less than 0.01 | ← | |
| Journal diametermm | 49.976~50.00 | ← | |
| Journal oil clearancemm | 0.016~0.040 | 0.05~0.07 | |
| Crankpin diametermm | 41.976~42.000 | ← | |
| Crankpin oil clearancemm | 0.024~0.048 | 0.04~0.06 | |
| Thrust washer widthmm | 2.43~2.48 | ← | |
Timing Chain, Sprocket
| Deflection limit (load 10kg)mm | 13.5 | ← | |
| Vibration damper thickness limitmm | 7 | ← | |
| Tension plunger head thickness limitmm | 12 | ← | |
| Camshaft timing sprocket wear limitmm | 113.8
(Measure diameter w/chain installed) |
| Crankshaft timing sprocket wear limit | 59.4
| Chain deflection limitmm | 272.7
(load 5kg) |
2 pages of tables to go...
