Tech:Engine/A Series/Converting to RWD
Revision as of 03:04, 9 June 2005 by MedicineMan (talk | contribs)
Crossmembers
Engine Crossmember - You can use the engine crossmember from an AE71/AE86 as the engine mounts will bolt straight up. If you have a KE70 crossmember, you will have to get custom engine mounts made.
Engine Mounts
You can use the engine mounts from an AE71/AE86 4A-C engine or have some custom made. Realise that custom made engine mounts require engineering.
Flywheel / Clutch / Pressure Plate / Throwout Bearing
There are 2 different size 4AGE flywheels, for 200mm and 212mm clutches. If yours is the 200mm clutch, just buy an AE71/AE86 200mm clutch kit. If yours is the 212mm Clutch, you will have to buy an AE92 100KW 4AGE 212mm clutch kit (also you will have to buy a throwout bearing from an AE86, as the AE92 clutch kit throwout bearing is completely different).
Spigot Bearing
FF / MR mount 4AGE engines do not have a spigot bearing in the crankshaft. You can press a spigot bearing from an AE71/AE86 4A-C into the crankshaft.
Gearbox
There are 2 main options for a gearbox
Clutch Master / Slave Cylinders
If you install a 4AGE into a KE70, it is easiest to put the pedal box and clutch master cylinder in from an AE71 (as the KE70 came with a cable clutch). With an AE71/AE86 you should already have a clutch pedal and clutch master cylinder (provided its not an automatic gearbox). You can use whatever slave cylinder came with your gearbox, though you may need to get the metal clutch lines made up.
Tailshaft
Intake Manifolds
There are 3 options for your intake, these are also dependant on if your 4AGE is smallport or largeport.
Cooling System
Radiator - A standard AE86 radiator will have no problems keeping a 4AGE cool.
