Differential Gears
Japanese
Borg Warner
KE5x and 7x Corollas in Australia had Borg Warner differentials, you can't change these centers as easily as in a Jap diff. KE5x have 6" ring gears, KE70s have 6.38". Apparently some KE1x cars had a Borg-Warner type diff as well, limited info available on these. KE20s have Borg Warner diffs from when they were made in Australia. All KE25s were imported, so they all have Jap diffs.
Comparision
So which is stronger? It really depends who you talk to. I personally would prefer a Jap diff, because even if you do destroy a center, it's bloody easy to change. I have seen both types of diff stand up to a decent amount of punishment (traffic light launches, weekend racetrack action, etc) behind a 96kw 4AG in a KE30.
Both factory diffs take 1L of oil. A common trick is to park your car on a downhill slope, so you can put more oil in, useful if you have a worn center or are running thinner oil or are just giving your car a hard time.
Upgrades (different housing)
Common upgrades are a Celica/T18/Corona T series 6.7" diff (clutch-type TRD LSD centers available AU$1200 ex-Japan, Cusco and Kaaz also available for more money), R31 Skyline diff (factory 4-pinion clutch-type LSD and disc brakes), 8" Hilux diff (many ratios and LSD available, rumored to be quite heavy), Mitsubishi Scorpion (LSD and good ratios available out of some L300 vans, but rare), even live-axle Datsun 1600 (wagon).
Depending on the car you are putting it into (obviouly KE3x, 5x and 7x are a bit wider than KE1x and 2x) just about any bigger diff you want to use is going to have to be shortened and have leaf mounts welded onto it. If putting into a KE3x, 5x or 7x, then Celica/T18 diffs will fit without shortening, but with the correct mounts welded on. With any of these, you'll obviously need to do something about your tailshaft.
Limited Slip (without changing housing)
Ratios
First digit: ring gear diameter
| A | 138mm |
| B | 145mm |
| C | 6.25" |
| D | 6.62" |
| E | 7.1" |
| F | 7.5" |
| G | 8" |
| H | 9" |
| J | 9.25" |
| K | 9.5" |
| L | 10.5" |
| M | 12.5" |
| N | 13.5" |
| P | 14" |
| Q | 12" |
| R | 162mm |
| S | 6.38" |
| T | 6.7" |
| U | 6" |
| V | 10.6" |
| W | 15.5" |
| X | 142mm |
| Y | 158mm |
| Z | 202mm |
| No ring Gear | FWD |
Second, third digits: gear ratio
| 01 | 3.30 |
| 02 | 3.36 |
| 03 | 3.545 |
| 04 | 3.556 |
| 05 | 3.70 |
| 06 | 3.889 |
| 07 | 3.90 |
| 08 | 4.111 |
| 09 | 4.222 |
| 10 | 4.375 |
| 11 | 4.444 |
| 12 | 4.625 |
| 13 | 4.79 |
| 14 | 4.875 |
| 15 | 5.125 |
| 16 | 5.286 |
| 17 | 5.60 |
| 18 | 5.714 |
| 19 | 5.833 |
| 20 | 6.167 |
| 21 | 6.667 |
| 22 | 6.78 |
| 23 | 6.833 |
| 24 | 7.64 |
| 25 | 4.556 |
| 26 | 5.571 |
| 27 | 3.364 |
| 28 | 4.30 |
| 29 | 4.10 |
| 30 | 3.727 |
| 31 | 3.909 |
| 32 | 6.591 or 4.807 |
| 33 | 7.503 or 5.583 |
| 34 | 6.781 or 4.786 |
| 35 | 7.636 or 5.60 |
| 36 | 4.778 |
| 37 | 3.583 |
| 38 | 3.417 |
| 39 | 3.154 |
| 40 | 5.375 |
| 41 | 3.308 |
| 42 | 6.500 |
| 43 | 3.550 |
| 44 | 3.214 |
| 45 | 3.533 |
| 46 | 2.928 |
| 47 | 3.944 |
| 48 | 3.356 |
| 49 | 3.729 |
| 50 | 3.400 |
| 51 | 3.736 |
| 52 | 3.722 |
| 53 | 3.250 |
| 54 | 3.941 |
| 55 | 3.333 |
| 56 | 2.821 |
| 57 | 4.058 |
| 58 | 3.238 |
| 59 | 3.234 |
| 60 | 3.519 |
| 61 | 2.724 |
| 62 | 2.892 |
| 63 | 2.655 |
| 64 | 4.312 |
| 65 | 3.837 |
| 66 | 3.071 |
| 67 | 3.526 |
| 68 | 3.095 |
| 69 | 4.176 |
| 70 | 5.857 |
| 71 | 2.962 |
| 72 | 3.949 |
| 73 | 4.285 |
Fourth digit: no of pinions, ltd slip-yes/no
Code pinions LSD
| 2 | 2 | no |
| 3 | 2 | yes |
| 4 | 4 | no |
| 5 | 4 | yes |
Application guide
5.6" (X)
Starlet KP61 81-82
5.7" (B)
6.0" (U)
6.25" (C)
Corolla TE21,27,28 (some) 71-74
6.38" (S or R)
6.62" (D)
6.7" (T)
