Series:K/Model/KE50/KE55/Ke55 Round Headlight Conversion
Jump to navigation
Jump to search
Fairly straight forward in the conversion. About the only parts needed are
- Headlight buckets
- Adjusting springs
- Adjusting screws
- Chrome surrounds
- Grill
Tools
- Phillips screw driver
- Needle nose pliers
- Hacksaw blade or something similar to cut the brackets
Yellow circles are the brackets that need to be removed, red circles are where the adjusting screws go into (new clip things and the screws, you should be able to get from an auto shop), the blue circles is what the spring goes onto.
Note
If you use KE55 round headlights, use a KE55 round headlight grill, and if you use KE35 round headlights, use the KE35 grille. The cups that the lights sit in are different, and if you mix and match the grilles the lights look funny (sit too far in or out).
http://www.rollaclub.com/board/topic/5958-ke55-round-headlightfront-end-conversion/
Edited by towe001
