User contributions for Philbey
Jump to navigation
Jump to search
9 July 2012
- 00:0200:02, 9 July 2012 diff hist +388 N KE1x Rear Diff - convert to 4x114.3 Created page with " Australian built KE1x (the AMC versions) are fitted with the same Borg Warner rear diff as a Datsun 1200, which runs a 4x114.3 stud pattern. There may be options to swap axl..."
- 00:0000:00, 9 July 2012 diff hist +43 Main Page Old →Drivetrain
19 January 2010
- 00:2800:28, 19 January 2010 diff hist +324 Installing a KE17 Tacho Dash into KE11/16/18 No edit summary current
- 00:2500:25, 19 January 2010 diff hist +1,618 N Installing a KE17 Tacho Dash into KE11/16/18 No edit summary
- 00:2400:24, 19 January 2010 diff hist 0 N File:Dashpinske11to17.jpg No edit summary current
- 00:2000:20, 19 January 2010 diff hist 0 N File:Dashpins.jpg No edit summary current
- 00:0400:04, 19 January 2010 diff hist +50 Dash Cluster No edit summary current
12 September 2009
- 09:3409:34, 12 September 2009 diff hist +5 Removing Spigot Bearings No edit summary
- 09:3409:34, 12 September 2009 diff hist +47 N Talk:Removing Spigot Bearings No edit summary current
- 09:3309:33, 12 September 2009 diff hist +766 N Removing Spigot Bearings No edit summary
- 09:2709:27, 12 September 2009 diff hist +32 Main Page Old →[[:Category: Drivetrain | Drivetrain]]
16 March 2009
- 00:0300:03, 16 March 2009 diff hist +226 Tech:Engine/K Series/Blocks →Description
22 February 2009
- 01:3301:33, 22 February 2009 diff hist −1 Tech:Engine/K Series/Blocks →Description
- 01:3201:32, 22 February 2009 diff hist +345 Tech:Engine/K Series/Blocks No edit summary
26 May 2008
- 11:0211:02, 26 May 2008 diff hist +98 South Australia No edit summary current
- 11:0011:00, 26 May 2008 diff hist +1,141 South Australia No edit summary
- 10:4510:45, 26 May 2008 diff hist +1,788 N South Australia No edit summary
- 10:2110:21, 26 May 2008 diff hist +1 Victoria No edit summary current
- 10:2110:21, 26 May 2008 diff hist +16 Victoria No edit summary
- 10:1110:11, 26 May 2008 diff hist +6 Victoria No edit summary
- 10:1010:10, 26 May 2008 diff hist +3,381 N Victoria No edit summary
- 09:3609:36, 26 May 2008 diff hist +6 Overview No edit summary current
- 09:3509:35, 26 May 2008 diff hist +3,439 N Overview No edit summary
- 09:0909:09, 26 May 2008 diff hist +20 Main Page Old →Engineering your Car
- 09:0709:07, 26 May 2008 diff hist +63 Main Page Old No edit summary
21 May 2008
- 14:3414:34, 21 May 2008 diff hist +2,653 Lowering KE1x Front using KE2x parts No edit summary current
- 14:1214:12, 21 May 2008 diff hist +64 N File:New top in place.JPG KE10 Strut with a KE20 upper spring perch fitted using a spacer. current
- 14:0614:06, 21 May 2008 diff hist +31 N File:Spacer fitted.JPG Spacer sitting inside strut top current
- 13:5613:56, 21 May 2008 diff hist +54 N File:Top comparison.JPG KE20 upper spring perch on the left, KE10 on the right current
- 13:5113:51, 21 May 2008 diff hist 0 N File:Removed.jpg No edit summary current
- 13:5013:50, 21 May 2008 diff hist +456 Lowering KE1x Front using KE2x parts No edit summary
- 13:4313:43, 21 May 2008 diff hist +9 N File:Removed.JPG All apart current
- 13:3713:37, 21 May 2008 diff hist +66 N File:Rubber and multigrips.JPG Rubber wrapped around shock rod to grip while you rattlegun it off current
- 13:2513:25, 21 May 2008 diff hist +26 N File:Spring off 2.JPG Coil wound down strut body current
- 13:2313:23, 21 May 2008 diff hist +352 Lowering KE1x Front using KE2x parts No edit summary
- 13:2313:23, 21 May 2008 diff hist +55 N File:Spring off 1.JPG Pic with the spring "popped" off the lower spring perch current
- 13:1513:15, 21 May 2008 diff hist +2,348 N Lowering KE1x Front using KE2x parts No edit summary
- 13:1213:12, 21 May 2008 diff hist +67 N File:Ke1x assy no spring numbered.JPG KE10 front strut with the spring removed. Numbered for explanation. current
- 12:1012:10, 21 May 2008 diff hist +22 Main Page Old →Suspension
- 12:1012:10, 21 May 2008 diff hist +56 N KE1x Suspension Help KE1x Suspension Help moved to Replacing front strut inserts on your KE1x: Old name was confusing with the new menu structure for the suspension section. current
- 12:1012:10, 21 May 2008 diff hist 0 m Replacing front strut inserts on your KE1x KE1x Suspension Help moved to Replacing front strut inserts on your KE1x: Old name was confusing with the new menu structure for the suspension section. current
- 12:0812:08, 21 May 2008 diff hist −13 Main Page Old →Suspension
- 12:0312:03, 21 May 2008 diff hist +35 Main Page Old →Tech
- 11:5811:58, 21 May 2008 diff hist +45 m Main Page Old →Suspension
