User contributions for Super Jamie
Jump to navigation
Jump to search
10 January 2015
- 04:1704:17, 10 January 2015 diff hist +70 Tech:Engine/K Series/Electronic distributor No edit summary current
- 04:1604:16, 10 January 2015 diff hist +181 Tech:Engine/K Series/Electronic distributor →Suitable HEI Coil
- 03:5003:50, 10 January 2015 diff hist −17 Template:K Motor No edit summary current
- 03:5003:50, 10 January 2015 diff hist +62 N Talk:Tech:Engine/K Series/How to wire a 5k electronic distributor moved Talk:Tech:Engine/K Series/How to wire a 5k electronic distributor to Talk:Tech:Engine/K Series/Electronic distributor: Changing from howto to general knowledge article current
- 03:5003:50, 10 January 2015 diff hist 0 m Talk:Tech:Engine/K Series/Electronic distributor moved Talk:Tech:Engine/K Series/How to wire a 5k electronic distributor to Talk:Tech:Engine/K Series/Electronic distributor: Changing from howto to general knowledge article current
- 03:5003:50, 10 January 2015 diff hist +57 N Tech:Engine/K Series/How to wire a 5k electronic distributor moved Tech:Engine/K Series/How to wire a 5k electronic distributor to Tech:Engine/K Series/Electronic distributor: Changing from howto to general knowledge article current
- 03:5003:50, 10 January 2015 diff hist 0 m Tech:Engine/K Series/Electronic distributor moved Tech:Engine/K Series/How to wire a 5k electronic distributor to Tech:Engine/K Series/Electronic distributor: Changing from howto to general knowledge article
- 03:4903:49, 10 January 2015 diff hist +1,706 Tech:Engine/K Series/Electronic distributor No edit summary
- 03:3103:31, 10 January 2015 diff hist +68 N File:Vn-coil.jpg Holden 5.0L ignition coil, ideal match for 5K electronic distributor current
- 03:1103:11, 10 January 2015 diff hist +1,161 N Tech:Engine/K Series/Battery Created page with "== Standard Battery == The standard battery for KE3x/KE5x/KE7x is: * Width: 238mm (horizontal) * Depth: 138mm (horizontal) * Height: 186mm (vertical) * Terminal Height: 212m..." current
- 02:5502:55, 10 January 2015 diff hist −3 Template:K Motor No edit summary
- 02:5402:54, 10 January 2015 diff hist +45 Template:K Motor No edit summary
16 August 2010
- 22:2522:25, 16 August 2010 diff hist −62 m Tech:Engine/K Series/How to build a tough K motor name
20 July 2005
- 12:5412:54, 20 July 2005 diff hist +3 m Tech:Engine/K Series/How to build a tough K motor No edit summary
8 July 2005
- 08:1408:14, 8 July 2005 diff hist 0 m Tech:Engine/K Series/How to build a tough K motor No edit summary
9 June 2005
- 14:2314:23, 9 June 2005 diff hist +4 m Tech:Engine/K Series/How to build a tough K motor No edit summary
- 14:0814:08, 9 June 2005 diff hist +1 m Tech:Engine/K Series/How to build a tough K motor →Run In
- 14:0714:07, 9 June 2005 diff hist 0 m Tech:Engine/K Series/How to build a tough K motor →Run In
- 14:0614:06, 9 June 2005 diff hist +94 m Tech:Engine/K Series/How to build a tough K motor →Run In
- 14:0014:00, 9 June 2005 diff hist +4,307 Tech:Engine/K Series/How to build a tough K motor No edit summary
- 13:3213:32, 9 June 2005 diff hist +910 m Tech:Engine/K Series/How to build a tough K motor →Assembly
- 13:2713:27, 9 June 2005 diff hist +98 m Talk:Tech:Engine/K Series/How to build a tough K motor No edit summary current
- 13:2713:27, 9 June 2005 diff hist +1,921 m Tech:Engine/K Series/How to build a tough K motor No edit summary
- 13:1613:16, 9 June 2005 diff hist +21 m Talk:Tech:Engine/K Series/How to build a tough K motor No edit summary
- 13:1513:15, 9 June 2005 diff hist +55 Talk:Tech:Engine/K Series/How to build a tough K motor No edit summary
- 13:1413:14, 9 June 2005 diff hist +96 N Talk:Tech:Engine/K Series/How to build a tough K motor No edit summary
- 13:1313:13, 9 June 2005 diff hist +1,156 Tech:Engine/K Series/How to build a tough K motor →Bottom End Mods
- 09:3909:39, 9 June 2005 diff hist +516 m Tech:Engine/K Series/How to build a tough K motor →Air and fuel
- 09:3209:32, 9 June 2005 diff hist +739 m Tech:Engine/K Series/How to build a tough K motor →Downdraft Carbs
- 09:2809:28, 9 June 2005 diff hist +1 m Tech:Engine/K Series/How to build a tough K motor No edit summary
- 09:2709:27, 9 June 2005 diff hist −38 m Tech:Engine/K Series/How to build a tough K motor No edit summary
- 09:2709:27, 9 June 2005 diff hist +3 m Tech:Engine/K Series/How to build a tough K motor No edit summary
- 09:2609:26, 9 June 2005 diff hist +5,686 Tech:Engine/K Series/How to build a tough K motor No edit summary
- 08:5108:51, 9 June 2005 diff hist +18 m Tech:Engine/K Series/How to build a tough K motor No edit summary
- 08:5008:50, 9 June 2005 diff hist −22 m Tech:Engine/K Series/How to build a tough K motor No edit summary
- 08:4908:49, 9 June 2005 diff hist −3 Howto No edit summary current
- 08:4108:41, 9 June 2005 diff hist +22 m Tech:Engine/K Series/How to build a tough K motor No edit summary
- 08:4008:40, 9 June 2005 diff hist +3 Howto No edit summary
- 08:3608:36, 9 June 2005 diff hist +9,664 Tech:Engine/K Series/How to build a tough K motor No edit summary
- 06:1106:11, 9 June 2005 diff hist +63 N Howto No edit summary
- 05:5805:58, 9 June 2005 diff hist +4 m User:Super Jamie No edit summary current
- 05:5705:57, 9 June 2005 diff hist +94 m User:Super Jamie No edit summary
- 05:5705:57, 9 June 2005 diff hist +298 N Rollaclub:Protected page guidelines No edit summary current
- 05:5305:53, 9 June 2005 diff hist +108 m Tech:Engine/K Series/How to build a tough K motor No edit summary
- 05:5005:50, 9 June 2005 diff hist +249 m Tech:Engine/K Series/How to build a tough K motor →Block
- 05:4605:46, 9 June 2005 diff hist +36 m Tech:Engine/K Series/How to build a tough K motor No edit summary
- 05:4505:45, 9 June 2005 diff hist +29 m Tech:Engine/K Series/How to build a tough K motor →Gearbox
- 05:4505:45, 9 June 2005 diff hist −6 m Tech:Engine/K Series/How to build a tough K motor →Gearbox
- 05:4405:44, 9 June 2005 diff hist +1 m Tech:Engine/K Series/How to build a tough K motor No edit summary
