All public logs
Jump to navigation
Jump to search
Combined display of all available logs of Rollaclub. You can narrow down the view by selecting a log type, the username (case-sensitive), or the affected page (also case-sensitive).
- 00:24, 19 January 2010 Philbey talk contribs uploaded File:Dashpinske11to17.jpg
- 00:20, 19 January 2010 Philbey talk contribs uploaded File:Dashpins.jpg
- 14:12, 21 May 2008 Philbey talk contribs uploaded File:New top in place.JPG (KE10 Strut with a KE20 upper spring perch fitted using a spacer.)
- 14:06, 21 May 2008 Philbey talk contribs uploaded File:Spacer fitted.JPG (Spacer sitting inside strut top )
- 13:56, 21 May 2008 Philbey talk contribs uploaded File:Top comparison.JPG (KE20 upper spring perch on the left, KE10 on the right)
- 13:51, 21 May 2008 Philbey talk contribs uploaded File:Removed.jpg
- 13:43, 21 May 2008 Philbey talk contribs uploaded File:Removed.JPG (All apart)
- 13:37, 21 May 2008 Philbey talk contribs uploaded File:Rubber and multigrips.JPG (Rubber wrapped around shock rod to grip while you rattlegun it off)
- 13:25, 21 May 2008 Philbey talk contribs uploaded File:Spring off 2.JPG (Coil wound down strut body)
- 13:23, 21 May 2008 Philbey talk contribs uploaded File:Spring off 1.JPG (Pic with the spring "popped" off the lower spring perch)
- 13:12, 21 May 2008 Philbey talk contribs uploaded File:Ke1x assy no spring numbered.JPG (KE10 front strut with the spring removed. Numbered for explanation.)
- 12:10, 21 May 2008 Philbey talk contribs moved page KE1x Suspension Help to Replacing front strut inserts on your KE1x (Old name was confusing with the new menu structure for the suspension section.)
