Search results
Jump to navigation
Jump to search
Page title matches
- ...iously carby car for EFI conversion, or also for a rising rate carby turbo fuel set up. ...pump. If you used one of these setup in the above diagram, it would spray fuel all through your boot!!!5 KB (930 words) - 12:19, 14 May 2008
Page text matches
- [[Category: Fuel System]]63 bytes (8 words) - 23:56, 21 May 2005
- ...u may need to splice the tail light wiring into the new harness or pin the fuel pump wiring into your existing loom. '''Fuel System:''' You will need the fuel tank from the twincam as it has a swirl pot design that the pump sits in an2 KB (291 words) - 10:30, 24 November 2010
- [[Tech:Engine/K Series/Emissions System|Emissions System]] [[Tech:Engine/K_Series/4kstall|What is a fuel solenoid?]]1 KB (195 words) - 05:17, 7 January 2007
- == The Starting System == ...esel engine, Low injection pump speed prevents complete atomization of the fuel.3 KB (419 words) - 05:02, 7 September 2008
- ...pirated engine beforehand there is no in-tank fuel pump, only a mechanical fuel pump on the engine (driven by the camshaft). Japanese AE86 Sprinters on the (Lifter pumps are designed to suck the fuel, not pump it at a high pressure so you will also need to use a Hig pressure4 KB (733 words) - 04:26, 10 August 2007
- ...s to make the 4age work in RWD, namely inlet manifold, extractors, cooling system.<br /> ...engine, do it properly and either do a surge tank setup, or us a jap ae86 fuel tank, not covered in this article.<br />2 KB (279 words) - 09:52, 14 September 2012
- ...onment and is good for your motor but bad for you. Japan got rid of leaded fuel in 1972. ...get better mileage, or more power if you're a leadfoot :) As higher octane fuel is slower burning, the timing must be advanced to recognise a performance g4 KB (677 words) - 02:25, 16 September 2012
- Over time, carbon from running an overly-rich fuel mixture can accumulate in your head. This problem is more likely in older, *There are also fuel additives, called things such as Fuel System Cleaner, Carburettor and Injector cleaner, etc which can help.2 KB (302 words) - 07:49, 29 April 2005
- *[[Series:A/Model/AE80/82/4age Diagnostic System|AE82 4age Diagnostic System]] *[[Series:A/Model/AE80/82/Making A Fuel Pump Access Panel|Making A Fuel Pump Access Panel]]9 KB (1,265 words) - 09:49, 14 September 2012
- *[[Series:A/Model/AE80/82/4age Diagnostic System|AE82 4age Diagnostic System]] *[[Series:A/Model/AE80/82/Making A Fuel Pump Access Panel|Making A Fuel Pump Access Panel]]9 KB (1,341 words) - 09:31, 28 April 2014
- ...point or another did come with factory fitted EFI also known as Electronic Fuel Injection. These only ever came on the 4K and 7K engines. Both of which can ...ith the 4K-E engine, sporting a blistering 1290cc of displacement. The EFI system consisted of very long intake runners so that the throttle body could be lo8 KB (1,433 words) - 02:25, 16 September 2012
- ...oyota workshop manual that suggests this is part of the -C motor emissions system. ...r, having very little mixture adjustment, and it would seem they have poor fuel atomization qualities too (whoever heard of a standard carb running ''rich'6 KB (1,015 words) - 02:02, 16 September 2012
- The diaphragm-type fuel pump is mounted on the side of the block and actuated by a lobe on the cams ...rovide smooth performance during all operating conditions. The lubrication system is a forced feed, full flow filtering type. The trochoid gear type oil pump9 KB (1,260 words) - 02:00, 16 September 2012
- The computers that drive the 4AGE use a few different fuel metering methods, There are 2 different methods. An Air Flow Meter, Which m ...Gears and installing larger injectors. You can also upgrade your ignition system by removing your distributer and installing a CAS (Camshaft Angle Sensor) w5 KB (915 words) - 13:27, 17 January 2008
- === 4. FUEL SYSTEM & ACCELERATOR LINKAGE === | 1 || 11495-SP001 || Plate plug (fuel pump hole) || 132 KB (4,179 words) - 00:48, 18 September 2012
- ...ng point with a plate would be required. You should be upgrading your fuel system anyway so this won't be an issue. ...with a turbo to run fuel through it. Any carby that will provide adequate fuel/air flow (beit downdraft or sidedraft) for the application can be used in d14 KB (2,639 words) - 02:28, 16 September 2012
- ...tion sound is to die for, Though you will have to modify your ignition and fuel delivery systems. (I have heard of people converting back to a 3A-C distrib '''Cooling System;'''6 KB (1,111 words) - 05:28, 27 January 2008
- ...e easy solution. I also couldn't be arsed converting my car to an efi fuel system, wiring in a computer and all that jazz. I also like the self-tuneability o You'll need to work out some sort of fuel supply. I'd use a drawthru SU or sidedraft, but that's just me. Considering68 KB (12,724 words) - 02:28, 16 September 2012
