Tech:Engine/K-Series/TRD
Link by Taz_Rx
Transcription
People are encouraged to check any measurements or part numbers against the original manual in case of transcription errors.
Stage I
(1) Main modifications
a. Cylinder head gasket.
b. Piston
c. Piston rings.
(2) Required parts.
Description Qty.
Gasket,cylinder head 1
Ring set, piston 4
Piston w/pin 4
(3) Assembling standards.
Item Sports parts S. T. D
No. 1 No.2 No.1 No.2
Stage II
1. PISTON & PISTON RINGS
(1) Main modifications.
a. Piston
b. Piston rings
(2) Required parts.
Description Qty.
Ring set, piston 4
Piston w/pin 4
2. VALVE MECHANISM
a. Camshaft
b. Valves
c. Valve springs.
(2) Required parts.
Replace with the above parts.
3. INTAKE & EXHAUST SYSTEMS
a. Intake manifold.
b. Exhaust manifold.
(2) Required parts.
(3) Assembling procedures.
a. Carburetor.
b. Accelerator linkage.
(2) Required parts.
STAGE III
1. CYLINDER HEAD
Item Detail Size & etc.
Valve seat ring (IN.) "
Valve seat ring (EX.) "
Caution
At the same time with the modification of the cylinder head, perform the surface grinding of the cylinder block top surface.
(Refer to cylinder block paragraph.)
(2) Required Parts.
1 Head assy, cylinder
8 90116-KE001 Bolt, stud 2
9 90116-KE002 Bolt, stud 6
Caution
Caution
Contact surface angle 45°
Exhaust mm 1.2 +0.2 -0
d. Port grinding.
Intake.
Exhaust.
Combustion chamber capacity
As a unit - 22 ~ 23 cc
When assembled - 31 cc
f. Water jacket machining.
Caution
2. CYLINDER BLOCK
(2) Required part.
a. Surface grinding.
Cylinder block top surface
Warpage allowance - 0.02 mm
b. Boring.
Caution
3. PISTON & PISTON RINGS
a. Piston
b. Piston rings.
c. Piston pin.
(2) Required parts.
2 13011-KE006 Piston w/pin 4
List 8
Item Sports parts
Piston standard diameter mm
78.96 +0.02
-0
piston clearance mm 0.07~0.10
c. Piston pin.
List 9
Item Sports parts
Piston pin bore mm
20 +0.012
-0
Piston pin outer diameter
20 +0.017
+0.005
Caution
d. Piston rings.
List 10
Compression
ring
No. 1 No.2
Caution
====(1) Main modifications.
a. Connecting rod.
b. Crankshaft.
c. Flywheel.
(2) Required parts.
a. Connecting rod.
List 11
b. Crankshaft.
List 12
Roundness limit mm 0.008 0.01
Bend limit mm 0.02 0.03
c. Flywheel.
Crankshaft x flywheel
Tightening torque - 800kg.cm
Caution
5. VALVE MECHANISM
a. Camshaft.
The valve timing and cam profiles are revised.
List 13
mm
Valve clearance
mm
Cam top center
A B C D E F
EX:0.38
106 109
EX:0.35
110 110
EX:0.4
106 114
EX:0.3
104 110
b. Valves.
To improve the intake and exhaust efficiency and to lighten the weight, revised the shape and dimension.
List 14
IN EX IN EX
Head diameter mm 38 33 36 29
Stem diameter mm 6.6 6.6 8 8
c. Valve springs.
For high performance of the engine, revised the valve springs from single to dual type.
List 15
Item Outer Inner
Free length mm 41.8 37.6
Installed length mm 38 32
Installed load kg 16 7
Effective windings 3.3 5.8
Coil wire diameter mm 4.2 2.6
d. Valve spring retainer.
Revised the shape for dual spring type.
e. Valve stem pad.
To maintain contact surface with the rocker arm the pad will be utilized.
f. Rocker support.
Due to the revision of the valve length provided an addition machining on the standard part.
g. Rocker arm spacer
The spring between the rocker arm is replaced with the spacer to reduce the resistance.
h. Push-rod.
To lighten, the material is revised.
i. Valve lifter.
Provided an additional machining on the standard part for desirable lightening.
j. Timing gear (for camshaft).
Provided with 7 dowel pin holes for easy selection of the camshaft.
Reference
(2) Required parts.
2 13711-KE003 Valve, intake 4
10 90072-72661
90072-72681
Pad, retainer 8 "O"
13511-KE005 Camshaft
Caution
On the camshafts 13511-KE001 and 13511-KE005, as the cam for driving the fuel pump is not provided, electric fuel pump is adapted.
b. Valves
List 16
Item Sports parts
Face contact width mm
1.2 +0.2
-0
(limit) mm 0.08
Caution
Be careful with the face contact surface and contact width and the dressing of the valve and valve seat must be performed sufficiently.
c. Rocker support.
Cut the bottom surface of the standard part (13951-22010).
Parallelism limit of the rocker shaft center and rocker support bottom surface - 0.03 mm.
d. Valve lifter.
To lighten, reduceds(sic) the thickness of the standard part.
6. LUBRICATION SYSTEM
a. Oil pump
Partially revised the standard part.
b. Oil pan.
Due to up-right positioning of the engine, revised the shape.
c. Oil strainer.
Due to the revision of the oil pan, revised the shape.
d. Oil cooling system.
Newly established the camshaft driven oil cooler pump.
3 Drive set, oil pump 1
7 90301-44049 Ring, "O" 1 "O"
9 90404-KE001 Union 2
10 Clamp 6
11 90405-KE002 Union 4
12 90401-12075 Union 4 "O"
13 90430-12015 Washer 8 "O"
14 Hose, oil cooler
a. Oil pump.
Also, with the engine prior to April 1974, please always utilize the 15100-24100.
b. Oil filter.
For 3K model, utilize (15601-33020) or (15600-25100) for T and 2T models. When utilizing 15600-25010 modification is required on the oil filter bracket (15609-254010).
(Refer to Fig. 14)
Caution
If there is a by-pass inside the filter, it is desirable to utilize the 15600-25100.
As the front timing cover rear oil seal retainer shape differs from the 3K-H model engine (after April 1974) and 3K-B model, sufficient care should be taken upon installation and modification.
7. INTAKE & EXHAUST SYSTEMS
a. Intake manifold.
It is of separate type from the exhaust manifold and it is of alloy metal.
The ports are also enlarged to match the carburetor throttle bore to reduce the intake resistance.
To improve the exhaust efficiency, it is of 4-2-1 type and for 4-speed (for K-40) and for 5-speed (for T-50), these are made available.
c. Manifold stay.
Due to the separation of the intake and exhaust manifolds, the alloy metal stays are prepared for installation of the manifolds.
(2) Required parts.
9 92122-KE001 Bolt, stud 4
a. Intake manifold.
Grind the ports to match the size of the gaskets
Grind the ports similar to the intake manifold.
c. Manifold stay.
Grind the contact surfaces of the cylinder head and manifolds so that these can be connected with gradual curved surfaces without any irregularity.
8. FUEL SYSTEM
a. Carburetor.
Revise the throttle bore to meet the specification for high speed driving.
List 17
Item Specification
Throttle valve diameter 45∅
Small venturi 8011-1
Main jet size 160#~200#
Air jet size 180#~220#
Emulsion tube ET7772-2
Idle jet side 50#
Pump jet size 33#~
Needle valve size 170#
Fuel level height 8.0mm
Air horn length 50mm
b. Fuel pump & filter.
Due to the revision of the camshaft and carburetor, will utilize the electric pump.
List 18
Type Electro-magnet Diaphragm
Rated voltage 12V
Rated current 2.3A
(2) Required parts.
DHLA45 x 2
Caution
Upon installation of the fuel pump, the rubber mounting which is supplementary to the assembly, must always be utilized.
9. ACCELERATOR LINKAGE
(2) Required part.
a. Distributor.
The advancing device is revised to stationary type and also improved the durability of the spiral gear.
List 19
Vacuum type None Yes
Point gap mm → 0.4~0.5
Weight kg 0.7 1.1
b. Alternator pulley.
To prevent the over-running of the alternator during high speed, revised the pulley diameter.
c. Cooling system.
Replaced the radiator with a larger radiation.
(2) Required parts.
1 Distributor assembly 1
2 Pulley, alternator 1
Ignition timing
B.T.D.C - 38 ~ 40&°/4,000rpm
(2) Required parts.
Service Standards
Cylinder Head
1.2 +0.2
-0
Exhaust 1.5
1.2 +0
-0
Cylinder Block
Wear limitmm 0.2 0.06
Fitting loadkg 2000~3000 ←
Piston, Piston Pin, Piston Rings
Oil ringmm 0.015~0.06 ←
Oil ring mm 0.015~0.06 ←
Connecting Rod, Bearing
Specified mm 0.110~0.214 ←
Crankshaft
Bend limitmm 0.03 0.02
Timing Chain, Sprocket
(Measure diameter w/chain installed)
(load 5kg)
2 pages of tables to go...
