Front Disc Brakes
All discs are all interchangeable (the Corolla hubs are the same except for wheel stud pattern), or if you change hubs as well, KE1x and 2x have smaller inner wheel bearings than the later cars. If changing from smaller disc to larger disc, you will need caliper mounts from a KE30 or KE55, as KE70 caliper plates have a different stud pattern. On most KE1x/2x cars, you will have to drill a tap the caliper mounting plates, as the later model plates use larger bolt holes to mount to the strut.
Upgrades for KE1x
Directions For Fitting:
17. Bleed the brake system.
Upgrades for KE3x, 5x, 7x
1. Corona XT130/RT132 struts and brakes. These come in 2 flavours - either single pot or twin pot.
2. The much-talked-about Peugeot 604 discs, Hilux/Landcruiser calipers, on XT130/RT132 struts. Effective, but rather heavy.
3. RX7 calipers and some sort of disc (?)
4. Vented AE86 struts and brakes. This isn't really much of an upgrade as the AE86 brakes aren't overly big, and neither are the calipers, but it does help cooling.
5. Magna discs, Commodore calipers (?)
6. Silvia/200sx struts, brakes. This is apparently a fairly straightforward swap.
7. If using Silvia/200sx struts, then the many many brake upgrade options from there (Skyline etc)
Back to Brakes
