Front Disc Brakes
Jump to: navigation, search
General Information
Upgrades for KE1x
Directions For Fitting:
17. Bleed the brake system.
Upgrades for KE3x, 5x, 7x
  • Corona XT130/RT132 struts and brakes. These come in 2 flavours - either single pot or twin pot. For some photos, look at Corona front brake upgrade photos on Planet FookStar
  • The much-talked-about Peugeot 604 discs, Hilux/Landcruiser calipers, on XT130/RT132 struts. Effective, but rather heavy. For some photos, look at Pug/Landcruiser brake upgrade on Planet FookStar
  • RX7 calipers and some sort of disc (?)
  • Vented AE86 struts and brakes. This isn't really much of an upgrade as the AE86 brakes aren't overly big, and neither are the calipers, but it does help cooling.
  • Magna discs, Commodore calipers (?)
  • Silvia/200sx struts, brakes. This is apparently a fairly straightforward swap. For some photos, look at Craig's Datsun 1200 on Planet FookStar
  • If using Silvia/200sx struts, then the many many brake upgrade options from there (Skyline etc)
And here are some photos:
Back to Brakes
Rollaclub
