Front Disc Brakes
General Information
Upgrades for KE1x
Directions For Fitting:
17. Bleed the brake system.
Upgrades for KE3x, 5x, 7x
- Corona XT130/RT132 struts and brakes. These come in 2 flavours - either single pot or twin pot.
- The much-talked-about Peugeot 604 discs, Hilux/Landcruiser calipers, on XT130/RT132 struts. Effective, but rather heavy.
- Silvia/200sx struts, brakes. This is apparently a fairly straightforward swap.
And here are some photos:
Back to Brakes
