Tech:Engine/A Series/Blocks
Jump to navigation
Jump to search
Toyota A Series Engines
Below is a listing of the basic specifications of some of the Toyota A-Series Engines. These are currently restricted to engines that were released in Australian specification Corollas, or that are now readily available from halfcuts from Japan.
Specifications
| Engine | Years | Bore | Stroke | Displacement | Valvetrain | BHP | lb-ft | Compression Ratio | Notes |
| 4A-C | 1983-86 | 81.0mm | 77.0mm | 1587cc | SOHC 8v | 70@4800 | 85@2800 | 9.0:1 | AE71, AE86 |
| 4A-F | 1987-90 | 81.0mm | 77.0mm | 1587cc | DOHC 16v | 90@6000 | 95@3600 | 9.5:1 | AE82, AE92 |
| 4A-FE | 1989-93 | 81.0mm | 77.0mm | 1587cc | DOHC 16v | 103@5600 | 101@4800 | 9.5:1 | AE92 |
| 4A-FE | 1993-98 | 81.0mm | 77.0mm | 1587cc | DOHC 16v | 115@6000 | 109@4800 | 9.5:1 | AE102R, AE112R |
| 4A-GE | 1985-86 | 81.0mm | 77.0mm | 1587cc | DOHC 16v | 112@6600 | 97@4800 | 9.4:1 | AE82 GTi & Seca SX, AW11 MR2, Bigport |
| 4A-GE | 1985-89 | 81.0mm | 77.0mm | 1587cc | DOHC 16v | 122@6600 | 105@5000 | 10.0:1 | Bigport |
| 4A-GE | 1990 | 81.0mm | 77.0mm | 1587cc | DOHC 16v | 130@6800 | 102@5800 | 9.5:1 | Smallport |
| 4A-GE | 1991-92 | 81.0mm | 77.0mm | 1587cc | DOHC 16v | 130@6800 | 105@6000 | 10.3:1 | AE92 GTi, Smallport |
| 4A-GZE | 1986-90 | 81.0mm | 77.0mm | 1587cc | DOHC 16v | 145@6400 | 140@4000 | 8.0:1 | AW11, early AE92, 8psi, bigport |
| 4A-GZE | 1989-91 | 81.0mm | 77.0mm | 1587cc | DOHC 16v | 165@6400 | 140@4400 | 8.9:1 | AE92, 10psi, smallport |
| 4A-GZE | 1991-95 | 81.0mm | 77.0mm | 1587cc | DOHC 16v | 170@6400 | 152@4400 | 8.9:1 | AE101, 10psi, smallport |
| 4A-GE 20v (Silvertop) | 1991-98 | 81.0mm | 77.0mm | 1587cc | DOHC 20v VVT | 165@7800 | 120@5600 | 10.5:1 | AE101 |
| 4A-GE 20v (Blacktop) | 1998-00 | 81.0mm | 77.0mm | 1587cc | DOHC 20v VVT-i | 170@? | ?@? | 11.0:1 | AE111 |
| 6A-FC | 1985-88 | 76.0mm | 77.0mm | 1397cc | DOHC 16v | 82@? | 87@? | 9.5:1 | AE82 |
| 7A-FE | 1993-00 | 81.0mm | 85.5mm | 1762cc | DOHC 16v | 115@5600 | 115@2800 | 9.5:1 | AE102R, AE112R |
