Tech:Engine/A Series/Blocks
Toyota A Series Engines
Below is a listing of the basic specifications of some of the Toyota A-Series Engines. These are currently restricted to engines that were released in Australian specification Corollas, or that are now readily available from halfcuts from Japan.
Specifications
Engine Years Bore Stroke Displacement Valvetrain BHP lb-ft Compression Ratio Notes
4A-C 1983-86 81.0mm 77.0mm 1587cc SOHC 8v 70@4800 85@2800 9.0:1 AE71, AE86
4A-F 1987-90 81.0mm 77.0mm 1587cc DOHC 16v 90@6000 95@3600 9.5:1 AE82, AE92
4A-FE 1989-93 81.0mm 77.0mm 1587cc DOHC 16v 103@5600 101@4800 9.5:1 AE92
4A-FE 1993-98 81.0mm 77.0mm 1587cc DOHC 16v 115@6000 109@4800 9.5:1 AE102R, AE112R
4A-GE 1985-86 81.0mm 77.0mm 1587cc DOHC 16v 112@6600 97@4800 9.4:1 AE82 GTi & Seca SX, AW11 MR2, Bigport
4A-GE 1985-89 81.0mm 77.0mm 1587cc DOHC 16v 122@6600 105@5000 10.0:1 Bigport
4A-GE 1990 81.0mm 77.0mm 1587cc DOHC 16v 130@6800 102@5800 9.5:1 Smallport
4A-GE 1991-92 81.0mm 77.0mm 1587cc DOHC 16v 130@6800 105@6000 10.3:1 AE92 GTi, Smallport
4A-GZE 1986-90 81.0mm 77.0mm 1587cc DOHC 16v 145@6400 140@4000 8.0:1 AW11, early AE92, 8psi, bigport
4A-GZE 1989-91 81.0mm 77.0mm 1587cc DOHC 16v 165@6400 140@4400 8.9:1 AE92, 10psi, smallport
4A-GZE 1991-95 81.0mm 77.0mm 1587cc DOHC 16v 170@6400 152@4400 8.9:1 AE101, 10psi, smallport
4A-GE 20v (Silvertop) 1991-98 81.0mm 77.0mm 1587cc DOHC 20v VVT 165@7800 120@5600 10.5:1 AE101
4A-GE 20v (Blacktop) 1998-00 81.0mm 77.0mm 1587cc DOHC 20v VVT 170@? ?@? 11.0:1 AE111
6A-FC 1985-88 76.0mm 77.0mm 1397cc DOHC 16v 82@? 87@? 9.5:1 AE82
7A-FE 1993-00 81.0mm 85.5mm 1762cc DOHC 16v 115@5600 115@2800 9.5:1 AE102R, AE112R
Back to A Series Engines
Rollaclub
