Tech:Engine/K Series/Gearboxes
T40/T50 (Toyota Factory 4/5 Speed Manual)
The T50 gearbox is a lot stronger than the K50 gearbox and is a split casing design. You can still purchase close ratio gearsets for the T50 gearboxes through TRD and also Quaife. The T40 or T50 gearbox can be adapted to a K series motor with a K-T Bellhousing,
2. Hydraulic clutch K-T Bellhousing, Rare, Requires hydraulic clutch setup to be installed. (Off KT174 5K T40/Carina, KT14x series Corona)
CLUTCH FOR K-T50: Although the K-T50 bellhousing in any form is very rare, nearly every clutch manifacturer make a kit for it. When looking for a ke20-70 clutch kit you may be asked "is it a 19 or 21 spline?"
The T50 box has a 24.1mm input shaft with 21 splines, this is the 21 spline kit you may be asked if you have. It still bolts to a stock 3k/4k 180mm flywheel, hence the clutch dimentions are 180x24.1x21T.
You may also notice that between different clutch manifacturers the middle number in the dimentions (input shaft diametre) may be different. For example PBR list the K-T50 kit as 180x28.3x21T. This is because they measure the diametre of the shaft in the vallies, whereas say Exedy measure it on the peaks of the spline.
The W5x (W50/W55) gearbox will fit if you use a K-W bellhousing from a KR42 Townace.
See also:
Article by Medicine_Man / Taz_Rx / Xany / tojo2
Back to K Series
