Tech:Engine/K Series/Gearboxes
T40/T50 (Toyota Factory 4/5 Speed Manual)
The T50 gearbox is a lot stronger than the K50 gearbox and is a split casing design. You can still purchase close ratio gearsets for the T50 gearboxes through TRD and also Quaife. The T40 or T50 gearbox can be adapted to a K series motor with a K-T Bellhousing,
2. Hydraulic clutch K-T Bellhousing, Rare, Requires hydraulic clutch setup to be installed. (Off KT174 5K T40/Carina, KT14x series Corona)
CLUTCH FOR K-T50:
Although the K-T50 bellhousing in any form is very rare, nearly every clutch manifacturer make a kit for it. When looking for a ke20-70 clutch kit you may be asked "is it a 19 or 21 spline?"
You may also notice that between different clutch manifacturers the middle number in the dimentions (input shaft diametre) may be different. For example PBR list the K-T50 kit as 180x28.3x21T. This is because they measure the diametre of the shaft in the vallies, whereas say Exedy measure it on the peaks of the spline.
GEARBOX SELECTION - Which one to use?
There are a few different type of T50 gearboxes, and you need to be selective on which one you use for a K-T.
Shifter position:
TA22 & T18 T50's share a "ke30-55" shifter position. The AE86 and AE71 T50's have a "ke70" shifter position.
TA22 & T18 T50's both also have a 20 spline output shaft, just like a ke20-70 corolla. The gearbox is also the same length so there is no tailshft mods required to use one! The later (AE86/AE71)ones are 22 spline output and will require the tailshaft yoke to be swapped.
The WX0 (W40/W50) gearbox will fit if you use a K-W bellhousing from a KM20-36 Liteace.
This bell housing will bolt up to 4x of the 7x bolt holes on a W40 or W50 gearbox, however you will need to grind a small amount out of the back of the bell housing to clear a "welse plug looking thing" on the gearbox - see the below link for pictures of this. I have mine bolted to (see below pic) an RA40 celica W50.
CLUTCH and FLYWHEEL: There is only one option when it comes to clutches & flywheels for this GB combo. You need to use the KM20-36 (beit 4k or 5k) flywheel, clutch fork, throwout bearing retainer, and clutch kit. The flywheel on a litace has the same overall diametre as a corolla one, however it has a bigger 200mm clutch plate surface. The W50 input spline is the same as a liteace one so it all then matches up. Clutch dimentions are 200x29.8x21T and here is the exedy listing..... http://www.exedy.com.au/SpecSheet.aspx?SpreadsheetRowId=14772 Even though this is a 'light commercial' clutch kit, exedy still make a brass buttom option!!!! hahaha - That would be fun in a loaded up van!!!
TAILSHAFT: The W50 GB is the same overall length as a K40/50, so no tailshaft shortening/lengthening is required. However the output spline is MUCH bigger and a corolla tail shaft needs to have the RA40 yoke transplanted onto it. This can be done with an old Holden (of all things) uni joint!!
See also:
Article by Medicine_Man / Taz_Rx / Xany / tojo2
Back to K Series
