Front Disc Brakes
All discs are all interchangeable (the Corolla hubs are the same except for wheel stud pattern), or if you change hubs as well, KE1x and 2x have smaller inner wheel bearings than the later cars. If changing from smaller disc to larger disc, you will need caliper mounts from a KE30 or KE55, as KE70 caliper plates have a different stud pattern. On most KE1x/2x cars, you will have to drill a tap the caliper mounting plates, as the later model plates use larger bolt holes to mount to the strut.
Parts Required: 2x KE20 front wheel hubs (*MUST* be KE10/mazda stud pattern.) About $20 each 2x KE30 disc rotors. Really good ones will cost about $40 each. 2x KE30 disc calipers. About $30 each. KE30 caliper/brake lines (rubber) Will come with the calipers. 2x KE30 caliper mounts/backing plates. About $10 each. KE30 brake pads. About $20 a set. Brake fluid of your choice $7 - $80 depending on what you buy. KE10 wheel bearings (optional) About $20 or so each. (you want to buy two) Directions For Fitting: 1. Attach KE30 disc rotors to KE20 wheel hubs. This is by four 12mm or 14mm bolts. Make sure you do them up nice and tight. 2. Disconnect the brake lines to the front drum. 3. Remove the outer part of your front drum brake. 4. Prise off the locknut cover with a flat head screwdriver. This is the big knobby thing right there in the middle. 5. There should be four bolts within the brake assembly holding the assembly to the stub axle. Undo them. 6. Use a pair of pliers to remove the retaining pin from the locknut and undo it. 7. Remove drum assembly from car.
8. Attach the backing plate to the four bolts that previously held the drum to the strut. 9. Get the hub/disc assembly you put together a few minutes ago. 10. Put this new assembly onto the stub axle. 11. Fit the locknut but not tight and don’t bother fitting the retaining pin yet. 12. Attach the caliper (and new pads) to the backing plate and over the disc. 13. Hook up the KE30 brake line onto the bracket on the KE10 strut (this will screw straight in). 14. Do up the locknut so the wheel will rotate freely but without wobbling around. Also put in the retaining pin. 15. Fit the wheel and do the same to the other side of the car. 16. Check all your bolts to make sure you did them up tight! 17. Bleed the brake system. 18. Do a test drive (drive slowly) to make sure everything works alright. 19. Don’t forget to be gentle on the brakes for a few days to let them bed in too.
