Search results
Jump to navigation
Jump to search
- 5K(solid lifter, D-Dish piston) - 180mm 5k(hydraulic lifter, D-dish piston) - 150mm (Part No. 13781-13100)1 KB (215 words) - 02:15, 16 September 2012
- ...ad the pushrods had to be changed from ball - ball ends to ball and cup. I'd heard somewhere that A12 Datsun pushrods are a one peice ball and cup pushr edit by AE25 - due to this same question being asked all the time I'd put together a solid lifter conversion FAQ which may be useful here3 KB (603 words) - 02:16, 16 September 2012
- * 20/22 mm for twincarb motors (3K-B, 3K-D). ...igger than that. I also have a Nikki 28/32 off a Mazda of some kind that I'd like to try out.6 KB (1,015 words) - 02:02, 16 September 2012
- ...luminium head, by design, they must have hardened steel valve seats or you'd drive around the block once and your motor would be fucked.4 KB (677 words) - 02:25, 16 September 2012
- ! Item !! Sports parts !! S. T. D !colspan="3"|S. T. D32 KB (4,179 words) - 00:48, 18 September 2012
- raise the engine for working room. I'd loosen right off the back 3 or4 KB (767 words) - 02:02, 16 September 2012
- <td width="11%">3K-D</td>9 KB (1,260 words) - 02:00, 16 September 2012
- With a bonus for people with KExx chassis id'd cars, these engines are a much more straight forward "bolt-in" option (comp == D.I.Y. EFI ==8 KB (1,433 words) - 02:25, 16 September 2012
- the bit where jamie can edit the main page is cool :D9 KB (1,265 words) - 09:49, 14 September 2012
- ...oom between the block and the inner guard with clever manifold design. You'd have to move the alternator to the other side but that's just a bracket or You'll need to work out some sort of fuel supply. I'd use a drawthru SU or sidedraft, but that's just me. Considering the small a68 KB (12,724 words) - 02:28, 16 September 2012
- the bit where jamie can edit the main page is cool :D9 KB (1,341 words) - 09:31, 28 April 2014
