kamikaze ind
New Member
kamikaze ind's Achievements
  1. Item Summary: 1984 s12 Gazelle Notch WILL SWAP Location: TAS: Regional Condition: Good Reason for Selling: Change Asking Price: 4000 Delivery Methods: PickUp Contact Info: pm Extra Information: standard features: 2-door rear wheel drive coupe power windows 6-dial dash digital clock power mirrors pop-up headlights 4-link rear end mod list: inside: cd player 300zx Z32 steering wheel boost gauge Monza 3-point harness (ADR approved) engine: CA18DET JDM ACL Race series piston rings, rod-end bearings, 1.3mm metal head gasket permaseal VRS kit CA20E water pump CA16DE timing belt modified oil pump with oil feed restricter in head tapped rods S14 T28 exceedy super heavy duity organic clutch front mounted intercooler 2.5in mandrel bent exaughst poddy with hectikc cold air intake Dr. Drift re-tuned ECU surge tank VL-turbo external fuel pump 12in thermo fan thermo fan controller suspension: welded h190 diff 16in alloys w 205/55R16's S13 hubs, brakes and knuckles S12 tie rod ends R31 lower control arms and caster rods with R31 ball joints S13 pro sport coilovers adjustable camber tops extended wheel studs on the front EL Falcon rear short stroe heavy duty shocks cut VN commodore wagon springs All gauges work, so tacho now works. Also has new plugs runs 14psi on a safe tune $4000 pm or msg 0437 696 872 Car goes good, does good skids. perfect ameatuer drift car can drop off at the boat as i live 15mins away from Devonport. WILL SWAP
