jake1010
    8
Everything posted by jake1010
  1. did some reading about the pcv and didnt learn to much. I popped the hose off it and its got suction but how do i test the acctual valve... From what ive read a shitty pcv will only realy give you a crap idle.. Is this correct? How can i check the jets? When i look in the first stage throat i can see fuel getting sprayed around but can't in the second one.
  2. did some reading about the pcv and didnt learn to much. I popped the hose off it and its got suction but how do i test the acctual valve... From what ive read a shitty pcv will only realy give you a crap idle.. Is this correct? How can i check the jets? When i look in the first stage throat i can see fuel getting sprayed around but can't in the second one.
  3. yep i set points to .45mm that right?? I set the timming to about +15 and it didnt seem to do much.. I also played around with the mixture screw and it didnt make much of a difference either all the way in or out....
  4. well at the risk of coming across as retard... How do i set the dwell time.... I did some reading and it sounds like you need a dwell meter. Is there away around this... Cause I'm broke as... I set the timing and the points today and now the problem seems to have changed a little bit... Now it wont accelerate very well.. From idle to about 1/8 throttle its alright but any more and it just gluggs abit and pretty much dies... Hmmmm.... @Scott. Iam not sure what ur talking about with the high idle issue... My carb only has on pipe coming out of it and its for the vaccum advance...
  5. or should i say is it easy to get accurate on a 4k?
  6. is it easy to static time a 4k??? Any tips?
  7. Thanks i spoke to a mechanic out near wilcania and he said to fill the things with silocone.to replace the seals.. Not a fan but might be a last resort.. i don't have a brake booster because its actually a 4k in a morris minor.. So that rules that out... Excuse the ignorance but what is a pcv?? Cheers
  8. hi all.. After a 3000k drive through the outback ive got a few problems.... 1. The aluminium cover things that the spark plugs sit in leak oil at high revs.... Can i just replace the seals or is this a bigger problem? 2. The oil pressure swith leaks.... Is this a standard part? Ie can i get any old one from supersheep or repco? 3. Runs like a dog when not accleterating... Sort of splutters.. From what ive read it sounds like a vaccum leak... Starts easy.. Thoughts?? 4. Idles high when warm??? 5. Is there any old topics/wikis that can tell me how to tune the carby... Ive never worked a dual throat thing before and don't really know whats going on...
