emeseey
New Member
  • Real Name
    Lachlan
emeseey's Achievements
  1. DEPOSIT TAKEN, PENDING PAYMENT
  2. No worries mate. I suggest if you want to do something about it you better be quick. I had someone look yesterday, an interested party look this morning and have a guy coming round Saturday morning. I do not mind accepting a deposit whilst you organise payment but first who comes back to me with a deposit is going to get it.
  3. Hi guys, Well my beloved 200B SSS Coupe has regrettably come up for sale. Only selling due to starting career in Realestate and in need of a more 'sensible car' :( This car has spent 99% of its life inland Victoria so its 100% rust free. I am the third owner, it was originally purchased in Bendigo (still has original dealer boot tag on rear window) and then was sold to fellow in Echucha, who I purchased it from. I had to jump through hoops to get it registered here so all of the hard work has been done for someone to take advantage of. The car turns heads wherever it goes, has a super strong engine, is incredibly reliable and will not disappoint its next happy owner :) Here are the details of the buckets of cash that has been spent on it: DETAILS: L20B Engine has been blueprinted and balanced, flat top pistons (comp was 9.8:1 befor head shim was removed),U67 head has larger inlet valves (45mm from memory) and a full port job done, combustion chambers have had all sharp edges removed and the valves un shrouded, CROW cam (Stage 3 or 4 I am not sure but I have the spec sheet) and heavier valve springs, re curved S2 bluebird electronic ignition with 8mm leads, twin 40 DCOE webber carbs on a match ported manifold, extractors and a full 2 1/4in exhaust (sounds incredible when you open it up :wink: ), AIR CONDITIONING! You better believe it, it works well too! Baffled trap door style rally sump, H/D clutch, dog leg 5 speed box, Independent Rear Suspension (IRS) locked diff which is a bit noisy as you would expect (also comes with the original open diff which is as smooth as silk), 120amp alternator, New battery, TRX rims also comes with the original 200b 14s with good tyers, sports steering wheel, Sony Head Unit, Cadence 4" Speakers, fire extinguisher, fender mirrors, tow hooks, tow bar, bonnet pins and boot straps etc. RECENT WORK: Weber Carbies have just been serviced and tuned. It has new front ball joints, front shocks, sway bar bushes, front brake hoses, radius rod bushes, idler arm bushes, alternator, coil, front brake pads and rear brake shoes, exhaust, radiator has been flushed, all oils have been changed and new spark plugs fitted. Car will come with 3 months SA rego and number plates SSS 078. This car would perfectly suit a weekend club/sprint/hillclimber/motorkhana enthusiast but is also a charm as a daily driver which is what I used it for. Car has never been raced. BE QUICK AT THIS PRICE: $4950 Car is located at Glenelg, Adelaide Please do not hesitate, Call Lochie 0421 507 765
