shaun1200
    7
Everything posted by shaun1200
  1. Yeah mate its a little gold one in the engine bay , not the normal one I see or use, so I should spend the extra cash and time and try and sort the weber out , I figured it would be better but was also considering about ditching the electric pump and trying to rum the mech one again
  2. its got an aftermarket electric fuel pump, does it need a reg to regulate the pressure even its a low volume pump if you hold your foot just on the accell pedel it coughs and farts and runs like shit , then if you put your foot down it runs fine, also if you put the clutch in , without letting the revs die right down it stalls, i brought a 32/36 weber for it should i bother stuffing around with the standard carb or just bite the bullet and throw the weber on will the weber be alright as it will be my daily once i sell my ute
  3. Yeah no worries , I'm getting 4 New tyres on the standard 12in rims on Monday as well as a wheel alignment and I'm going to replace the idler arm bush as well as the rear shackle bushes, so hopefully that helps abit with the handling side of things
  4. thanks mate, I'm going to do a full service on it once i get a day off , going to do plugs, leads, dizzy cap, rotor button, oil and filter, fuel filter, air filter, then hopefully that knocks a few things out
  5. Yeah mate electronic dizzy by the looks of things ,
  6. just brought my first ke11 and noticed how bad it tracks with the grooves in the road, is there anything to help this or is it just something you have to get used to??? at the moment its running 13x175mm meshies but i was hoping by throwinging the 12in stockies back on and doing the idler arm bush as well as the rear shackle bushes it would help cut it down a bit any ideas??? cheers
  7. just brought my first corolla which is a 69 ke11 with a 5k in it its running pretty rough and was just wondering who around my local area would be able to give it bit of a tune its running standard carby at the moment and should run alot better than what it does, i know most mechanics would be able to do it but just thought id chuck it out there and see who you rolla boys would reccomend I'm located in penrith, ive had plenty of dattos before, (a14 turbo 1200 ute, ca18det 1200 sedan, ca18det 1200 ute, ca18det 120y wagon, + a few stock datos but I'm new to the corollas, any help appreciated cheers
