4DRFRK Posted February 20, 2008 Report Posted February 20, 2008 (edited) i was on the way home from a mates just now in the ke55 (first drive since getting it back woot) and hit the brakes hard to avoid a 4wd that just pulled out in front of me "c**t" and since then my brakes have made a noise similar to when your brake pads are worn only 100 times worse, only you don't have to have your foot on the brake the noise is there all the time , any ideas as to what could have happened. Its almost the same as when i poped a wheel cylinder in my old skyline excpt the noise is way louder than that (luckily it happened about 100 meters from my house i just drove home and parked it i plan too look at it saturady any ideas as to what may have happend so i know what to look for Thanks daniel HAD CUT A BRAKE PAD ALL FIXED Edited February 29, 2008 by 4DRFRK Quote
superbmobile Posted February 20, 2008 Report Posted February 20, 2008 hey mate check if the pads haven't worn through to metal. Also how much fluid do ya have in the master slaves could be sticking and brakes could be locked on a bit. so check and bleed ya brakes. I had a similar problem with my old cressida. Quote
