Chev/holden Solid Lifter Q
hey all this is my first post here just signed up, anyhow ive been reading alot of posts about changing from hydro to solid in a 5k....well today i scored some chev/holden solids for $4.02 each thats kiwi dollars too. so $32.04 later i have some.i have the 4k adjustable rocker gear but now its ummm n ahhhh about the pushrods. I'm reading theres a million different options depending on things.
so ive got dished pistons shallow head and a fair wack taken off, will be running a fairly agro cam too, i think its duration @ .050" camlift: 250 lobe seperation: 108
anyhow the lifters compress just a little when you squeeze them...is that normal for the chev solid.i know it looks like a toyota hydro but yea...how will that work with the rocker gear?will i lose valve lift from the small compression? (if that makes sense)
and then theres which push rods do i go for? i have 5k hydro ones which are no good as they are round at each end, i have what i think is 4k rods and thats it,and i don't want to buy 5 sets to see which fit so I'm hoping someone here can help me out as the chev conversion seems popular in aus.
cheers
Chris
cheers
Chris
You need to use Datsun A12 /1200cc pushrods.
Matt
