November 17, 200818 yr comment_290601 hey people just wanting to know if ke30 struts and brakes will fit onto a ke17 sprinter? just as a quick upgrade. from what i can see they run a leaf spring from side to side. if it can be done could this leaf be removed? Report
November 17, 200818 yr comment_290643 Your best bet is to switch to KE20 strut tops and then upgrade the springs. Check the FAQ article I wrote up, it's a cheap and easy fix. And yes, from previous discussion you will be able to run without the transverse leaf if you upgrade springs. Report
